Results 401 to 410 of 420
- 54,261
September 19th, 2015 11:34 AM #401- - - - - - - - - - - - - - - - - - - - - -
i suppose that about wraps it up.. ?
is it advantageous? if there is threat of fire, yes. someone said that this is the reason nitrogen is used in serious racing..
is it worth the expense? only if it is free.
it's something like car air conditioning.. the advocates then, advertised that with air conditioning, your car will be more fuel-effective, because driver would be driving with the windows closed, reducing wind resistance..
...complicated reasoning, that needs to be analyzed carefully..
i have a question.. if it is true, that if the tire carcass does indeed let oxygen out and not nitrogen..
is it possible, that after several refills with ordinary air, the gas inside that tire will already be nitrogen-enriched, because the oxygen will have seeped out already..?
that means, after several re-fills with ordinary air, practically every tire out there will be nitrogen-enriched already...
placebo..? dunno..Last edited by dr. d; September 19th, 2015 at 11:41 AM.
September 19th, 2015 12:02 PM #402
There is some truth to this in practice. When I first used nitrogen on brand new tires, I noticed that the tires were loosing pressure quite rapidly. I had to refill weekly (around every 5 days). After a few refills, pressure stabilized, so now, I only refill every 5k, when I have my wheels rotated, for free of course. I surmised that the smaller molecules were leaking out when being displaced by the nitro. So you don't have to deflate & inflate.
September 19th, 2015 12:31 PM #403
If you plan to go Nitrogen, never re-inflate it with ordinary air. The air will just seep out. Check tire pressure regularly. Also, will be practical to have the nitrogen source close by, in case refills have to be done.
- Aug 2012
- 2,767
September 19th, 2015 01:07 PM #404If free, why not. If may bayad, nevermind.
I use regular air lang. I have my own portable tire inflator and digital tire air pressure gauge at home. Even with ordinary air, it takes few months before the tires lose air pressure and need to refill.Last edited by red_one; September 19th, 2015 at 01:23 PM.
September 19th, 2015 02:02 PM #405
- Aug 2012
- 2,767
December 23rd, 2015 04:17 PM #408
I always thought it was a scam. If you detest reading long scientific journals, watch this instead.
https://youtu.be/bCnWvMleVD0
December 23rd, 2015 11:02 PM #409
For some reason, I don't take Aussies seriously. They say & do a lot of bullshit. I liked Tiff Needles segment better. In any case, just my opinion, my experience with nitro better than air. I refill every 5k whenever I have my tires rotated, as compared to every week with air.
December 24th, 2015 01:10 AM #410
Fun fact: Since air is already 80% nitrogen, and nitrogen diffuses more slowly through porous rubber, AND the Law of Partial Pressures dictates that for the gases that CAN diffuse through the rubber, the partial pressure should be the same inside the tire as in the outside air...
What does this mean?
Fill your tire with 99% pure nitrogen and the oxygen from outside will permeate through the tire... leaving you with a 85-90% nitro-oxy mix if you don't regularly top off.
Fill your tire with regular air, and the oxygen leaks out over time. Keep refilling it and eventually, you will have 85% or greater nitrogen inside your tire.
Source:
http://www.nhtsa.gov/DOT/NHTSA/NRD/M...009/811094.pdf
Some further reading:
Barry's Tire Tech
And read post 110 here:
Nitrogen tires - Page 3 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com
for some laughs... the guy kept his tires inflated to 42 psi for over a year, reinflating as oxygen filtered out. At the end of that time, apparently, most of the oxygen was gone and the air was mostly nitrogen. Not enough oxygen to feed a lighter flame. Not a precise test, but an "illuminating" one. And as time went on and oxygen filtered out, he had to add less and less air to the tire. My tires are the same. After a year of putting high pressures in, they barely lose any pressure over a month.
This is not to say nitrogen doesn't help... but simply reinflating your tires regularly and keeping tire inflation pressures high will, eventually, result in tires that lose less pressure over time. All without having to pay extra for the nitrogen you're ALREADY getting from a regular air pump.Last edited by niky; December 24th, 2015 at 01:46 AM.
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
