Page 1 of 2 12 LastLast
Results 1 to 20 of 27
    Jan 2012
    help! I have a toyota yaris with skirt and it's 5-6 inches off the ground, any kind of hole or bumps in the road hits the skirt
    My mechanic told me to get 16 inch tires/rims I currently have 14 inches
    please advice! I wanted to remove the skirt but he said my car would look bad without the skirt
    Should I get 16 inches or 17 inches? How does it affect my car? How much does 2nd hand mags usually cost? Is the 2nd hand mags worth it or should I buy a new one? (cost wise)
    thank you in advance!
    tanggalin mo na yung skirt. ayos lang yang walang ganyan. tingnan mo yung itsura ng mga stock na yaris.
    kung lalakihan mo ang gulong mo kakainin nyan ang fender liner. Mas lalo ka pang mag ingat kung naka 16 o 17 ka. mas problema yan sa mga pot holes.
    Jul 2006
    Quote Originally Posted by winter View Post
    sayad na yan sa fender paps. lalo dadami problema mo. let go of the skirts
    Jun 2007
    sounds like meron gustong kumita from the new sets of tires/wheels
    removing the skirts sounds reasonable and less expensive.
    i wonder if getting a thicker tire, R14 80 or 90 series would help your vios stand a little higher without changing your current rims?
    Aug 2004
    Increasing tire diameter can result in fender-rubbing, loss of power, poorer fuel economy and odometer error.
    The simplest solution is to remove the skirts. The simplest and cheapest solution that does not require removal of skirts is to install higher spring perches or spring spacers, which will raise your car roughly half-an-inch for every 1 inch thickness. This maintains the stock tires, stock spring and shock damping and stock fuel economy.
    Personally, 5-6 inches of clearance is not really that low. There are modern cars that are just 5 inches low without skirts. If you're scraping the ground after every pothole, then it's not the skirts, it's because your suspension is suck-tacularly soft.
    (that's on the road, the tires aren't squealing, and yes, it's bottoming out.)
    Just learn to drive around it... drive slower... or buy stiffer springs and shocks.
    agree. it's not really that low. yung ek ko dati 3/4 nung kaha ng yosi ang ground clearance pero ok naman. sumasayad minsan sa humps pero pag tama yung approach mo sa mga humps walang sayad.
    Oct 2005
    I think you are currently rolling on 15s. 185/60R15 if it's stock.
    I also agree that it's not that low yet. Learn to drive around humps more carefully, change your approach/passing/departure angles.
    Jan 2012
    thank you for the replies! your answers help me a lot, thank you. you are very helpful!
    I think the reason why other answers say that 5-6inches isn't low enough is because you live in the big city. I live in mindanao, which a lot of the roads have holes and our humps are huge and some roads aren't even cemented
    my tires read 185 / 60 r14 - 14 means 14 inches? I am not the first owner of this car so i'm not sure if it's stock or not
    also when parking, you know the parking bumper? that was my first damage because I was taught to hit the tire into the bumper, but the tire wasn't the one hitting the bumper, it was the skirt huhuhu :'(
    picture of parking bumper for reference
    also I'm having doubts on removing the skirt because I don't like the look of the car without it, I am interested in this
    "install higher spring perches or spring spacers, which will raise your car roughly half-an-inch for every 1 inch thickness"
    thank you very much!
    Aug 2004
    I live in the province. I used to drive a lowered Sentra that had just four iinches or less clearance at the front chin. Even over potholes and ruts, completely fine. I had to go all the way to Makati to rip the front chin.
    You just have to get used to eyeballing what your car can and can't clear. Even some crossovers and SUVs scrape their front chins on humps and parking stops.
    Jan 2012
    thank you niky
    my problem with is that i'm not the only one using my car, my boyfriend uses it when he goes to school and just yesterday when parking he accidentally hit the parking stop / parking bumper (ouch! the paint was destroyed) :'(
    i'm wondering how much would this cost?
    higher spring perches or spring spacers?
    Sell the Yaris then get an SUV...
    Kidding aside, just learn how to "siyete" on humps. Then drive slow on potholes. 5 inches off the ground isn't low. I used to drive a car that's lowered, and had no problems with it. Occasional scraping lang sa fenders when I go all out sa EDSA.
    Aug 2004
    Boyfriend better pay, girl.
    Those are the stakes of owning a car with a front chin. Whatever you do, it WILL get scratched. The question is not "if", it's "when" and "how bad..."
    *TS, palagay ka ng rubber lifters sa 4 na gulong mo. ganyan din problema ko sa gsr ko. Nung nabili ko kasi yun eh lowered siya kaya nagpalagay ako ng 1 inch sa lahat ng gulong, ayun hindi na siya masyadong sumasayad sa mga humps at hindi ko na rin kailangang mag-7. Yung sa iyo mukhang stock pa naman kaya mas mataas pa yan keysa sa ground clearance ng kotse ko. Try mo, sarap din kasing magdrive ng walang inaalalang sasayad sa ilalim ng kotse eh...
    Hirap kasi dito sa atin mananawa ka kaka-7 sa kalsada eh...
    Jan 2012
    *nicky - hahaha definitely no need paying, it was an accident
    thank you erick,
    is this what you mean by rubber lifters?
    I saw polyurethane lifters at 2,500php and rubber at 600php? is there a big difference if I get the expensive ones?
    thank you erick,
    Hi winter,
    Hindi ganyan, yung pinalagay ko kasi yung bilog na swak sa spring tsaka sa suspension niya...
    Aug 2004
    The spacers are like this.
    Jan 2012
    thank you for the replies but sadly I coudn't find those products here and
    after doing a "do it yourself" fix on my front skirt and tried driving really safely and slowly(avoiding pot holes, bumps, etc.), just yesterday I drove from the parking lot where there's a downhill road and made another very ugly crack in my front skirt! :'(
    After careful observation I realized that the reason why I bumped from the downhill road was because I was with my sister, I usually drive alone from the mall. But besides that the 5-6inches off the ground when there's 4 people riding makes it like 2-3 inches off the ground! no wonder
    I think I really really need these spacers! but i have been looking for them but i can't seem to find anything except "O-sulee Spring Cushion" is this the same? please help me! thank you!
    As far as I know O-sulee doesn't increase the car's ground clearance, it only softens the ride.
    question lang, stock ba yang suspension mo? as in walang mods/upgrade?
    tingin ko spacer talaga ang kailangan mo sir... saka stiffer na spring/shocks siguro...
Car is 6 inches off the ground(with car skirt), need bigger tires?
