Results 1 to 20 of 33
    kapag ba pinarotate mo tires, do you need to have wheel alignment/balance?
    Dec 2002
    Balance yes because when the tires wear out they don't wear out evenly so you need to balance them especially the front at low speeds you wont notice but at high speeds you will feel the wiggle of the steering wheel. wheel alignment at least once a year.
    Aug 2006
    try to rotate it first, Then if you feel some vibration on your steering wheel you need to rebalance them.You need wheel alignment if you find that your tires have an even wear.
    Thanks a lot for the advice, Just in case where do you recommend I have my car balance? Sa casa or puwede na sa iba? TIA
    pwede naman sa casa...but practically, sa labas na para makamura.
    you can try wheelers suspension haus or mega motion in banawe.
    Quote Originally Posted by baiskee View Post
    Thanks a lot. I'll observed first my ride per your advice before I have it balance.
    I just rotate the tires. Even here at home. Kung may vibrations saka na lang ipa-check. Btw, I have all four tires balanced. So wherever they may be positioned, they are supposed to be balanced.
    Jun 2005
    Quote Originally Posted by OTEP
    I do the tire rotation myself every 10,000 kms. Nakadalawang rotate na ako. So far, okay naman at walang vibrations.
    Jan 2004
    normally a pineperform ang tire balance kapag na remove at kinabit uli ang tires sa magwheel...
    tire rotation as i read from a general service manual of toyota, is done every 10,000 or 5,000 km depending on your vehicle's drive train.
    kung part time 4wd or rear-wheel drive, it is done every 10,000 km, kung full time 4wd or front-wheel drive, it is done every 5,000 km... medyo complicated ito as to yung rotation pattern niya is variable din.
    before, i do it every 10,000 kms, i can see that the results are good naman, that time when my mileage registered a bit over 25,000 kms, my tires still look as good as brand new pa naman.... now, i'm doing it every 5,000 kms, i believe mas magiging ok yung result
    from my experience, to extend your tire's life span, tire rotation should be always be accompanied with the correct tire pressure.
    Jun 2005
    Quote Originally Posted by driven
    Nice tips, driven. I'm on my 28,000 kms. After I rotate my tires at 30,000 kms, I'd do the rotation every 5,000 kms. Thanks.
    Jan 2004
    Quote Originally Posted by j_avonni View Post
    anytime dude
    Mar 2005
    Mga sirs, sorry for the stupid question but do you need to remove the tires from the rims when you rotate or is it ok to rotate them rims included?
    Jul 2006
    Quote Originally Posted by fuego4x2 View Post
    kasama sir ang rim sa rotation
    Aug 2005
    Quote Originally Posted by 79gemini View Post
    nope. no need to remove the tires sir.. just shift it directly to your rear.. good luck!
    Mar 2005
    Quote Originally Posted by finchy18 View Post
    Salamat sa replies.
Tire Rotation
