Results 1 to 7 of 7
    May 2007
    mga peeps, newbie here.
    pa advice lang po.
    ano pwede gawin para tumaas yung likod ng sentra b14?.
    para iwas sayad sana tsaka di masyado bababa pagka may karga sa likod.
    maintain sana yung stock na height ng car sa harap tapos itaas lang ng konti sa likod mga 1" siguro.
    ano pinakamagandang gawin dito? palit ba ako ng spring... shocks...wheels?
    bundok dito sa amin tsaka medyo pangit mga daan kaya gusto ko sana medyo mataas na setup pero maporma pa din...
    Jan 2003
    Quote Originally Posted by tuwato View Post
    pa advice lang po.
    pa check mo muna shocks mo baka sira na kaya pag may karga ka mababa sya masyado.
    but kung ayos shocks mo and you still feel you need a lift, madami sa banawe rubber lifters, it sits on top of you springs, for that extra 1" lift
    Quote Originally Posted by impulzz View Post
    +1 dito... thats the only way to lift the ride height.
    yep..shock-mounted rubber lifters..done this on my two sedans.
    May 2007
    ^ thanks sa tips...
    Nov 2003
    yup, putting a lifter is the easiest solution.
    BTW, a "lifter" is the easiest way to raise the suspension to level out a car but it will not solve the source of the problem if your rear suspension bottoms out when you hit bumps on the road.
Raise the rear..(sentra b14)
