ano ba talagang mas maganda between a fluid type and a gas type? which is more suited for our road conditions? pros and cons in using either one?
Comfort: fluid front and rear
Hauling: gas ako esp rear in comb with fluid in front
Lowered: gas front and rear
The prime function of gas charging is to minimize aeration of the hydraulic fluid. The pressure of the nitrogen gas compresses air bubbles in the hydraulic fluid. This prevents the oil and air from mixing and creating foam. Foam affects performance because it can be compressed - fluid can not. With aeration reduced, the shock is able to react faster and more predictably, allowing for quicker response time and helping keep the tire firmly planted on the road surface.
http://www.monroe.com/tech_support/t...kabsorbers.asp
Koni sport adjustable shocks is the best suited for our road conditions. It will last the lifetime of your car.
old cars usually fluid type shocks ang nakakabit pero yung mga bagong models na car lahat almost gas type
usually we auto supplies recommend fluid sa harap then gas sa likod ...
pero mga cars ngayon gas type shocks na ang lumalabas kaya you have no choice but to change to gas type shocks
just my two cents, ano ba ang magandang alternative to OME if my budget is low?I have to change my rear shocks asap. Sira na eh. hehehe.
Question po, pwede bang gas sa front then fluid sa rear?
Ayos pa naman yung mga shocks ko, kaya lang, medyo stiff yung rear ko kaya parang gusto ko palitan ng fluid.
