Results 1 to 4 of 4
    MGA SIRS:
    Bka pwede nyo ho akong tulungan, may daihatsu hi jet 1000 me, at ang problem ko tuwing may lubak o khit tumatakbo lang, may maririnig na tsok, tsok na tunog parang goma na humihigop between and under ng driver and front passenger seats pero di nman nagtatagal nwawala rin, nung sinilip ko may nkita ako na parang rubber n korteng spring na nkakabit sa parang bar na gumagalaw tuwing turn ng steering wheel, at parang dun galing un sound. ano kya itong sound n ito, delikado b na it might cause an accident. please help,and how much kya to fix it. need info.
    Jul 2003
    pa-check mo lang yung suspension parts. baka kelangan na palitan shock absorbers, bushings at iba pang rubber components.
    always go to your trusted mekaniko.
    Dec 2010
    have you solved your problem???
    Dec 2010
    Quote Originally Posted by johnniebravo39 View Post
    MGA SIRS:
    The rubber you are referring to is the steering boot. If the sound seems to be coming from there, have a mechanic check on that component. Problems in the steering system may be dangerous if mechanical by nature.
tsok, tsok sound sa ilalim ng front wheels
