Results 1 to 7 of 7
May 24th, 2011 01:41 PM #1
Hello mga sir. Pahelp naman. Whenever na magsstep ako sa brake ng car ko (ford lynx gen1 m/t) I hear noise comming from the right front brake. Sounds likes "ongk ongk ongk."
Noong pinacheck ko brake ko, pinareface nila yung rotor, nawala yung tunog, then after a few days, bumalik ulit yung tunog.
Possible kaya na palitin na yung brake rotors ko?
At tsaka pahabol narin, may naririnig akong humming/ugong sound sa likod. Nagpalit ako ng wheel bearings sa likod, nawal din yung tunong, then ganun din, bumalik agad yung ugong, lalo na nung napadaan sa wet roads. Ano kaya possible po na ngcacause ng mga annoying sound na yan. Delekado po ba to? Thanks.
May 24th, 2011 11:49 PM #3
Okay padin yung brake pads sir. Nung chineck ng mekaniko yung brakes, uneven daw yung surface ng brake rotors ko kaya may ganung sound, so pinareface lang. Kaso bumalik din yung problem eh.
As for the ugong sound, ano pede reason ng madaling pagkasira ng bearings? Wala pa sya two weeks since pinapalitan ko eh. TIA
May 25th, 2011 05:55 AM #5
ok pa yung pads but anong klase siya? oem o yung replacement na? madalas kasi ang cause ng brake noise at uneven wear ng rotor ay yun mismong pads specially pag replacement na sobra tigas.... my cent
- Oct 2010
- 240
May 25th, 2011 06:40 AM #6
May 25th, 2011 04:16 PM #7
Thanks sa replies mga sir. Will try to buy the oem brakes nalang or okay ba kung yung bendix nalang?
Regarding sa rotor, baka bili narin siguro ako. Can i safely assume na dapat ko ng palitan rotors ko? The car is 11 years of age na with 150k sa odo. Thanks.
BYD Seal 5 DM-i vs. Honda Civic RS: Subcompact-compact sedan Big Test | Top Gear Philippines Top...
(11th Gen) Honda Civic
