Results 1 to 6 of 6
    Jul 2012
    Good afternoon mga bros..
    2014 Vios G Manual
    About to change my tires, halos pantay na ng indicator yung upod.. Planning to replace yung stock rims and tires with 205/50 r16.. Ang concerns/situation ko are the ff:
    1. Around 4-5 persons sa 1 1/2 hr trip (qc to makati).
    2. Medyo madami mga humps na nadadaanan.
    3. Occasional trips sa province (2-3 persons) 3 hrs up yung travel
    As mentioned.. ano pong brand ang mapapayo nyo? ang after ko sa tires yung better grip sa wet and dry (vs stock yokohama), durable (di bubukol, sumasabog at mabilis maupod) and matino ang price..
    Btw, should I go 16s, okay lang ba na di magpalit ng springs and shocks? if ever magpalit ako, ano po magandang set up, e.g. (KYB Excel G + TEIN/EIBACH etc.)? Habol ko lang bale almost stock ang comfort, kahit slightly lowered, and di sayarin..
    My apologies sa haba at dami ng tanong.
    Thanks so much..
    Quote Originally Posted by Dusty View Post
    2014 Vios G Manual
    Thanks so much..
    Plano ko rin magpalit ng wheel & tires. Problema lang, mahirap maghanap ng "16 tires & alloys. From 15, 17 na ang susunod. Ang ayoko naman sa 17s, matagtag at mabilis masira suspension (under warranty pa sasakyan ko).
    Jul 2012
    sa tires, medyo mahirap hanapan.. pero may mga available.. pero sa alloys.. madalas ng magandang design nasa 17 and 18 yung available na size.. kaya napili ko yung 16s kasi baka di ganun kalaki ang difference sa ride quality ng 15s.. kaso di ako sure kung sayarin ang 205/50 r16 na profile..
    Oct 2015
    Spec Sidewall Rad Dia Circ Revs/Mile Difference
    185/60-15 4.4in 11.9in 23.7in 74.6in 850 0.0% -stock
    205/50-16 4.0in 12.0in 24.1in 75.6in 838 1.4%
    195/55-16 4.2in 12.2in 24.4in 76.8in 825 3.0%
    195/50-16 3.8in 11.8in 23.7in 74.4in 852 -0.3%
    205/55-16 4.4in 12.4in 24.9in 78.2in 811 4.8%
    185/65-15 4.7in 12.2in 24.5in 76.9in 824 3.1%
    195/55-15 4.2in 11.7in 23.4in 73.7in 860 -1.2%
    source: http://www.miata.net/cgi-bin/tirescgi
    rule of thumb +3% ang acceptable kapag mag-plus size
    just dont get China or Taiwan tires. no offense po.
    Indonesia/Malaysia/Thailand/Philippines is ok. Low end yoko matagal maubos but not that grippy at maingay. Dunlop sticky pero mabilis maubos vs yoko.
    Bridgestone most recommened dahil tahimik, grippy and durable.
    problem nalang ay rare ang 16s para sa car :D
    had a vios with 185/65R15 on stock rims, hindi ganun kaporma tignan pero panalo sa pasahero at sa lubakan.
    2014 Vios G Manual
    Thanks so much..
    from 15, wala naman halos effect if you convert to 16 dun sa load mo and dun sa humps. hwag ka lang magpa lower.
    just make sure that you use the correct rim offset.
    Jul 2012
    Quote Originally Posted by PJ Sinohin View Post
    Quote Originally Posted by 1D4LV View Post
    Thank you so much..
205/50r16 tires and set up for 3rd Gen Toyota Vios 1.5G Manual
