Page 1 of 2 12 LastLast
Results 1 to 20 of 51
    Meron bang nagbebenta dito?
    sino manufacturer bro? si "george"?
    j/k
  3. #3
    Meron akong kilala nagbebenta ng Enoc (Middle Eastern brand) lubricants, just text me if your interested.
    Actually I'm specifically looking for Lucas Power Steering sealer, sya lang kasi proven na matino eh hehe...
    Mar 2003
    Yep...tried and tested na nga ito, based from AU and NZ users from the other forums i go too. I once tried looking for it but did not have any luck finding one. hehehe. pinaayos ko nalang ang PS ko.
    I wanna spend $10 kasi muna bago $$$ sa repair kit + labor or rack ehhe.
    Mar 2003
    exactly what i intended to do first..hehehe.
    the closest ones i found were that of cyclo (which probably will just worsen the prob), STP, etc.. I heard Valvoline also have their own equivalent sealers.
    yup, but sa mga reviews, Lucas lang pumasa hehehe...
    pag nakahanap ako balitaan kita pre.
    uy... ok yan theveed ha! power steering sealer! kailangan ko din yan! hehehe!
    yung suking mekaniko namin... gusto na ng silipin ung power steering ko. baka daw hose ang ang problema.
    sa ngayon tsaga lang mag topup ng ATF.
    lumakas bigla akin kasi hehe...
    Oct 2011
    Paano ba inaaply itong Cyclo?
    You might want to try the MAG1 POWER STEERING FLUID WITH SEALER & CONDITIONER.
    Seals & gaskets in older cars tend to dry out, harden & shrink, causing system leaks. Stop those leaks by adding a bottle of MAG 1 Premium Power Steering Fluid With Stop Leak when changing or topping off power steering fluid.
    Benefits of Mag 1 Premium Power Steering Fluid With Stop Leak include:
    Special 2 in 1 formula
    Stops system leaks
    Softens & conditions hardened seals & gaskets
    Smooths & eases steering operation
    This type of PSF will only work as long as it can close the gap.
    Worn-out seals should always be replaced ASAP.
    Apr 2009
    Itong Cyclo stop leak.. drain mo lang yung PS reservoir you can use suction. then pour lang sa reservoir.
    Sa mga naka gamit na ng Cyclo need your feedbacks..
    thank you
    i had repaired my PS assembly replacing those seals more than 2 years ago. So far, ok naman yung STP PSF. Until 2 months ago, pagdiagnose ng mekaniko ko, mga hose naman bumigay,.. ay sus ginoooooo... buti nalang mahina lang tagas, natutuluan alternator ko pati,.. shemay....gastos oh!
    *theveed: pre, balitaan mo ko kung may mahanap ka ha, interested ako dun, papa-replace na kasi ako ng mga hose nun soon ehh. Bigay ka nalang any info (kung price per bottle, liter etc etc.) TY! :D
    I'll be buying another brand later sa Concord, it'll be a while bago ako makakahuha ng Lucas hehe... Update ko kayo kung umubra :D
    I bought a bottle of Cyclo Power Steering Stop Leak sa Concord a few minutes ago, costs P179.75 only. We'll see how it goes.
    Previous condition:
    Both sides of the rack has a leak, the driver's side leaks around 5-6 tablespoon everytime you leave it for more than 6 hrs (ie, parking sa office or park at home overnight), the passenger side leaks around 2-3 tablespoon.
    The reservoir will be low on PS fluid (noise when turning) every 5 days or so, with visual reduction of fluid every time you check the reservoir (daily)
    Poured around 2/3 a bottle of the said product yesterday before leaving the office yesterday, around 6PM...
    Drove home (EXTREME TRAFFIC KAHAPON!), took me more than an hour from Ortigas to Manggahan... Then my wife used the car and drove for another hour and a half or so.
    She parked the car around 11PM last night, I placed 2 pieces of newspaper near the leak points.
    Checked the car this morning (11AM), and guess what... 2 drops on the driver's side and NONE on the passenger side. The newspaper were blown away by light winds hehe.
    Checked the reservoir when I got to the office 15 minutes ago, and the level is the same as yesterday!
    P179 vs. P4,500 for repair kit + labor hehe...
    Theveed... thanks for texting me this also... will be buying the said product hopefully later.
    Ang dungis na ng garahe because of my PS leak.
    hirap pa man din tanggalin ang PS fluid compared to motor oil...
    ayos ah...parang magic. :D
    gano kaya tatagal yan?
Power Steering Leak Stopper [Renamed]
