Results 1 to 10 of 30
    Oct 2008
    just want to ask po kung break po ba talaga or brakes? since ang usapan eh accident, i think i wanna learn how and why it happened. gusto ko rin po kasi matuto kaya napatingin ako sa thread na ito
    First it's spelled brake not break. What do you mean you lost your brake? Did the pedal just go to the floor or it just wasn't biting? If your brakes weren't bled correctly then you would have noticed this early on when you press on the pedals it will be soft. What the shop said doesn't make sense and you'd have to find out which brake did not function correctly. If the rear was the problem you should have still had enough braking capacity to stop because 80% of the work is done by the front brakes and only 20% for the rear brakes.
    mam, please check po yung brake fluid container kung nabawasan or hindi. kung nabawasan, possible may leak ang system. if not, mali ang pag bleeding nya. pero its a good thing wala po nangyaring masama sa inyo...
    Baka nag lock ang isang wheel kaya hindi ka nakapag brake ng sapat.
    May ABS ka ba? Remember once one or more brakes lock spells danger. especially kung wala kang ABS. Also having ABS doesnt guaranty stopping power, its job is to balance all wheels rpm at braking and correct them before it locks.
    Oct 2005
    Quote Originally Posted by 4JGtootsie View Post
    alam mo tootsie, i think your explanation is the closest to what could have happened. kasi wala naman leak.. and un din ung theory ng repair man. sabi nga bka nga daw nagstuck ung isang wheel and is still continued turning even if i pressed the brakes. and that's really how i felt when that happened.
    What could have caused the lock? wla ako ABS. sabi nung other repair shop which i went to right after the accident, hindi daw pantay ung rear breaks ko.. ung isa daw sobrang higpit and ung isa maluwag. But according to some ppl i talk to 20% lang daw ung impact nun since rear brakes nga. So bkit wla pa ring brakes? Haay.. im really at a lost as to what really caused it. kasi unless that's determined parang im always running the risk of losing my brakes.
    Oct 2005
    thanks testament! yeah thank God im ok and the one i hit. wla damage on his side.
    Wala leak according to shell, when the recheck it.. the only odd thing is medyo hindi nakamax ung fluid when i brought it to their shop for rechecking. d ba dapat its still full dahil one week pa lang naman when they had it bled and refilled. Pero sabi nila wla daw talga leak. although they assured me na wala na daw talga problema ung brakes ko after thorough checking, cleaning and adjusting the brakes. I really pray to God that they're right. Kasi medyo traumatic ung nangyari sa kin. nanginginig ako after the accident and medyo paranoid na ko about my brakes. hehe oh well, my only wish is sana sagutin ni shell ung repairs that i have to do for my car. they should take responsibility for that.
    Oct 2005
    Quote Originally Posted by redorange View Post
    yeah that's really odd nga.. kasi when i had it checked from another repair shop right after the accident yung rear brakes daw ung hindi pantay. So now im really confused as to how it happened na nawalan talga ng brake. I know for sure that it was really lost coz my distance is a car away before i pressed the brakes. d talga kumakagat.
    Oct 2005
    Quote Originally Posted by Burai View Post
    yeah my mistake.. brake sya hindi break. haha! :D
lost my newly installed brakes from shell customer cradle... :(
