Results 1 to 20 of 50
    Oct 2007
    Pano po ba tanggalin ito? Any preventive measures para di na magkaroon ng rust yung brakes ko? TIA
    magkaka rust yan talaga unless you have it painted. pag di mo nagamit ng matagal magkaka rust siya. pero once you use it mawawala din yun.
    Oct 2007
    ahhhhh... danun pala. de ku lam e. hihihih. tenchu po.
    Get disc that are cadmium plated they don't rust as much and as quickly. Otherwise just use the car and when you apply the brakes that will remove the rust.
    Aug 2006
    question bakit po mabilis siya kapitan ng kalawang??
    Jun 2006
    Because the bare Iron loses one of its electrons in reaction to air and water. It then becomes Iron oxide.
    Aug 2007
    madalas mangyari to pag maulan o kaya pag lumusong ka sa baha, pagpark mo sa bahay kinabukasan tadtad ng kalawang..
    Quote Originally Posted by Horsepower View Post
    WOW! genius
    Guys I need help. Is it normal for disc brakes to rust. The is brand new and only 3 months old btw. Here are some pics:
    Need advice po.
    sir matagal na ba hindi ginagamit? usually they do rust if you dont use the car especially now that its raining everyday.
    but if you do use it in a daily basis... now thats a problem. are these replacement or OEM?
    These are OEM from the day I bought the car. I use the car everyday from mondays to fridays. I seldom use it on saturdays and sundays. I washed the car yesterday. I used a hose to spray water on the wheels. Could that be the cause? Is it normal? I'm afraid that one day the rust will go deep and cause the brakes to become brittle and break.
    sir, im no car expert but i think it should not rust that much if its used daily.
    mine does rust also pero spots lang. try driving the car today then brake and go... if it goes away then i think your fine pero kung meron pa din, parang hindi na normal.
    hintayin na din natin yung car experts diyan... maybe they can explain further on what to do.
    May 2007
    Quote Originally Posted by hcdangan View Post
    Yes its very normal. Every time you wash your car and it sit's overnight rotor will rust or havent use for a few days specially in the humid area. Dont be alarm it will "shimmy shimmy bling bling" again after few kilometers of driving.
    Thanks to all the replies. Now I can sleep again
    ano pala cause pag yung disk brake binuhusan ng tubig nag steam siya
Rust in disc brakes
