- Forums
- Discussions
- Events
- Community
July 13th, 2009 02:27 PM
mga guru may power steering leak yung 1991 nissan maxima ko...
kanino ko po ba pede patingnan...
yung tagas nya di naman po ganun kalakas...pero mas maaga ko na patingnan...
yung makamura sana ako
salamat...
you can add me sa ym ko po...dtwaltus
di po kasi ako parati online
thank you
July 13th, 2009 05:05 PM
You will need to have it fixed because the leak will just get worst as time goes on.
Have the defective part replaced or rebuilt.
July 13th, 2009 09:36 PM
You can try to check the hoses. Could be that the clamps have loosened.
This happened to my 1992 L200. I replaced the clamps and the leaks have stopped.
July 14th, 2009 12:43 AM
check the hoses and the power steering pump for leaks and then replace what is needed.
July 14th, 2009 02:03 AM
Depends on where the leak is. Pag hose madali lang yan. Pag sa mismong gearbox kailangan ng repair kit to overhaul it.
