Results 1 to 10 of 10
    Jan 2008
    Problem ng car ko meron squeaky sound when steering ska kpg sa lubak.
    Front-Right Wheel...
    Una estimate nila 3k... tie-end-rod/rack-end pyag ako... eh di sinimulan na... ssnod may nkita 2k pa daw dahil meron pa sira(bushing)... then test drive 15mins...
    ok nman... then pinagawa ko yung sa likod dlwa gulong ( don't remember pero support arm sya... pair... dag dag ako 2k...
    puchat... tapos nung uuwi na ko... pag kabig ko ng manibela... tsk tsk... same problem...
    nilagasan ako ng 7k... mga a**hole...
    wag na wag kyo ppunta dito... dami dami pinalitan di pa din na solve problema ko.
    Feb 2009
    Quote Originally Posted by bensoniq140 View Post
    bensoniq,
    sounds like you got hit by shotgun wrong guesses and no diagnoses. sometimes too, the symptoms are difficult to replicate in the shop or some conditions are not met. maybe the person trying to isolate and pointed where the noises orginated from is deaf or has limited hearing.
    jick
    learn from experience na lang. next time check niyo muna sa mga topics dito. malaking tulong ang mga ito. like for your case sana nag cruven ka na lang. based from my experience sa kanila tangal lahat ng ingay sa ilalim , with warranty pa yan at hinde ka tatagain.
    Kadalasan kasi iyong iba trial and error siguro magandang gawin kung may paayos ka sa suspension check up mo muna sa isang shop .free naman check up .Palista mo kailangan palitan at presyo ng labor . At saka ka pumunta sa ibang shop para sa second opinion ng analysis nila para may basehan ka hindi kasi pare pareho diagnose nila . At para hindi ka rin mapasubo sa gastos.
    Hirap basahin post mo bro. Bawal sms/text typing dito. Make use of your keyboard...
    Regarding Motorex, I've been going there in the past mostly to buy parts, never had a bad experience with them. Baka nachambahan ka lang.
    actually mahirap din talagang i-isolate ang mga suspension squeaks and issues.
    baka may warranty sila. kung meron, ibalik mo. back job dapat yan.
    imho, na experience ko na din kasi yan sa cruven. after replacing all suspension parts, hindi pa din nawawala ang problema. good thing may warranty sila dun.
    Feb 2009
    bensoniq,
    if you go to yahoo main engine search and type "noise vibration and harshness diagnosis" you wil find a few hints and diagnostic tree diagrams on the most common automotive noises and some related diagnostic trees for other problems
    jick
    Nov 2007
    I have been to Motorex a few times and they have been successful with my suspension issues. Just bring your car back to them and let them do a back job.
    Nov 2006
    sa cruven ganun din. napalitan na lahat ng mga dapat mapalitan pero may mga tunog pa din na hindi mawala-wala... pero kapag nung binalik ko naman sa kanila, maayos naman nilang hinanap at nakita naman ang source... at wala nang bayad yung backjob.. all smiles pa rin sila... maayos sila kausap at puwede ka pa mag basketball habang inaayos oto mo... hehehe... ;)
    Okay naman experience ko sa motorex. It really depends on how bad your suspension is. Fixing by isolation siguro ang ginawa and many shops do this also.
    Make use of your receipt and bring it back.
Motorex philippines sa banawe mga hindi marunong!
