Results 1 to 10 of 13
- Jun 2008
- 12
May 4th, 2013 12:25 AM #1Hi everyone,
I have Honda Civic 2003 VTI-S car, 2nd hand lang po sya nung nabili ko. May problema yung car na tila di maayos ayos pag dinadala ko sa casa. Problem is when turning, may knocking sound pag malapit na sumagad yung steering (either left or right).
Dinala ko na minsan sa casa, may pinalitan pero hindi nawala yung katok so medyo dissappointed na ako. After ko mag complain, sinabi nila na kailangan daw magpalit ng steering gear (40k+ gear palang). I have no issue sana wag kaso nga parang wala nko tiwala parang trial and error ang ginagawa at napapagastos lang ako.
Any advice po or anyone with the same issue before, pag pinakikinggan ko yung sound, prang galing sa right side ng front wheel (upper portion), sorry hindi kasi ako magaling sa sasakyan so di ko alam yung mga terminologies/parts/etc.
Trying to post here baka makakuha ng advice.
Thank you.
- Nov 2011
- 79
May 4th, 2013 05:18 AM #2
I had almost the same issue back then..what i did was overhauled the rack and pinion. cost about 2k, check you rack and pinion if you have any leakage.
Mine is a Honda CRV 2003, contact me maybe i can refer you to my mechanic.
just an option..maybe i can save you 38k or more . heheheh
- May 2012
- 33
May 5th, 2013 12:45 PM #3Bicoy, Ipa inspect mo ang loob ng mga tires mo sa front baka nuong nagpa vulcanize ka or something ay may naiwan sa any
of the front tires at pag nag tu- turn lang kumakalansing
- Oct 2009
- 2,271
May 5th, 2013 07:15 PM #4gaano ba kalakas ang katok sound like tok tok tok ba?..
baka naman CV joint ang sira nya..
try mo pa check kahit sa zafra motors ,,or rapideA
BANNED BANNED BANNED
- Feb 2011
- 101
May 8th, 2013 07:20 AM #5Pa-check nyo na muna tie rod and rack end, baka palitin na. Mas mura naman yun before you go through rack and pinion overhaul
- Dec 2012
- 220
May 8th, 2013 05:39 PM #6Try zafra malapit sa mandaluyong city hall. Ganyan problem ko sa corolla namin dati ang daming tumingin pati steering inayos pero sa zafra isang test drive lang naayos agad. Forgot ano pinalitan definitely hindi sa steering.
May 8th, 2013 05:48 PM #7
start sa pinakamaliit muna
1. bushing
2. Tie Rod
3.Rack End
4.Rack & Pinion
between.. di ba yan kumakabig pakaliwa or pakanan?
- Jun 2008
- 12
May 8th, 2013 07:27 PM #8Hi Jansky, na acquire ko yung car in 2010 then I can't remember anymore when but nagpalit nko ng bushing (casa parts/labor). Other than those you mentioned above, di ko napapa check or napalitan. Regarding sa kabig, pag sa NLEX/SCTEX ako nagda-drive, may konting pa-kaliwa pero sobrang konti lang na iniisip ko dahil lang sa road condition.
Mga Sir, pag sinabing overhaul ng rack & pinion, yan ba yung term sa casa na "steering gear overhaul"? Ang sabi sakin dati sa casa (Honda Pasig sa Libis), di na daw sila nag-ooverhaul dahil bumabalik daw kagad sira so brand new nalang daw. Ewan ko kung totoo or gusto lang kumita.
Again, I'm not that too technical when it comes to car pero will try all your suggestions. Thanks po sa lahat.
- Jun 2008
- 12
May 8th, 2013 07:31 PM #10*jaypee10, hindi naman parang continuous tok tok tok, parang once lang sya na "tok". Matagal na sya actually nung una medyo mahina lang tapos medyo lumakas nalang ng konti yung tunog.
Wondering kung delikado sya in case na di kagad na-address ang issue.
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
