Results 1 to 20 of 21
    Dec 2009
    mga master patulong naman..
    ilang beses na ko nakapag pabonding at resurface ng mga drums ko pero di matanggal ang vibration pag namemreno ako at highspeed nakakatakot tuloy gamitin van ko..
    any tips mga master kung pano mawawala yun??
    Feb 2009
    Quote Originally Posted by RyanZeke View Post
    RyanZeke,
    what is your make, model and year of the vehicle? check the brake rotors too for warpage, runout and parallelism. don't forget about the wheel bearings, they too can cause wheel shimmy. assuming the tires are balanced and no defects, i.e.; out of round, warped or has flat spots and properly inflated, then you can check for the brakes. try rotating the tires this way: RF to LR, RR to RF, LF to RR and LR to LF. try the process of elimination. most shops don't have wheel spinners to check tire defects, wheel bearing noise and imbalance while the vehicle is in the shop supported by jack stands.
    jick
    May 2009
    boss ryan,
    ganyan din preno hanggang ngayon. pinareface ko lng kasi isang disc. ayun lalu pang tumindi yung vibrations while braking kasi yung isang disc mejo warped na rin. planning to change disc and pads nako by next week. pinacheck ko rin wheel bearings at yung castle nut na naghohold sa mga bearings mejo maluwag..pinarepack ko na lahat. inform kita kung ano mangyari after the parts replacement
    Feb 2009
    Quote Originally Posted by miked View Post
    boss ryan,
    miked,
    all brake discs or rotors have a minimum thickness marking on them. sometimes embossed, sometimes engraved or stenciled. if this minimum thickness is not met, and the rotor is thinner than minimum, the rotor warps from heat. thin rotors tend to get hot easier too.
    jick
    Nov 2007
    mga tsips,
    San pinaka mura magpa reface ng rotors sa qc area? Nag wiggle din ang manibela pag nag brake ako at 80 km/h up ang takbo. Gaano katagal ginagawa ito? sabi sa isang thread, kelangan daw yung di ordinaryo na machine lathe ang gamit kundi brake lathe (double bit).
    Salamat!
    hmmm, i think its much better to replace the rotors than to have it replaced. having it refaced, as like what jick said, would depend on the thickness of the rotors, and is not a guarantee that it will be ok after the reface.
    Dec 2009
    mga sir toyota hi-ace commuter po ung sasakyan ko drumbrakes lang po sya..twice na po resurfaced nung 2009 di naman po sya warped nagpalit na din po ko ng mga pads nya kaso ganun pa din tlga...
nagbavibrate habang napreno
