Does anybody know where i can have the Ecosport ABS module repaired? Saw this Fred Mechanic on YOUTUBE but no address so far. Preferably in the QC area. Thank you.
What are the issues or symptoms and why do you think the ABS module is defective?
It's typically one piece.... the motor, valves, and the controller. Kung fluid leaks lang in one of the plumbing flanges, those things can be fixed easily. Pero if it's something internal, kailangan nga marunong. It's a safety component so it's not something to be played around with.
Just curious and asking the OP how it was determined that the ABS module itself was faulty.
super common ecosport issue. the bean counters at ford picked the lowest biddergood thing i don't have that car anymore
Had the same issue with my 2012 Montero Sport. It was lighting up also.
The fix was just adjusting (aligning) the sensor (or some connector) found under the front bumper. The company mechanic said that baka na galaw lang sa car washing.
Saved me from going to the casa and probably having them recommend changing some parts
Might be worth looking into this first.
