Results 1 to 9 of 9
April 7th, 2010 12:10 AM #1
Good day..
i just recently replace my 2 front tire, then have it wheel balance, allign then pag takbo ng oto, notice mo agad na kabig sa kaliwa, sa dating gulong wala naman..medyo bago pa yung pinalita ko..nilipat kolang sa likod kasi pudpud na sa likod..
san kaya may problema dun? also may tunog pag liliko ako sa kanan and kaliwa..hinde naman malakas..pero ramdam mo yung parang tok tok..
help po...also yung sa driver side, grabend alog pag may small lubak pag straight yung manibela, pero pag medyo naka side ways wala yung kalog..
rack and pinion na kaya yun?
TIA..sensya po daming problema oto ko..
EK99 po
- Nov 2009
- 456
April 7th, 2010 12:52 PM #2Did these problems appear immediately after you had your tires replaced? If so, check if the bolts are loose. Also have the allignment and camber checked at another more reputable station with laser allignment equipment.
April 7th, 2010 01:02 PM #3
ano sabi nung nagkabit bro?new tires ba pinalit mo?dapat nga hindi magkaka ganun yan kasi pinalitan mo na.pero kung me kabig yan camber talaga kelangan ng auto mo. ayos rin ba kain ng gulong dun sa dati mong tires?pantay ba?yung mga natunog baka bushings lang.uu nga dalhin mo na lang sa servitek yan para isahan na lang.
- Mar 2010
- 1
April 7th, 2010 03:34 PM #4Bro new member po here sa tsikot, thru experience nung nagpalit din ako ng two front tires, that thing happened, paulit mo ang camber adjustment mo, i agree with CivicVTi.
. kung wala ng room for adjustment, usually what they do ay pina file ang upper or lower hole mounting ng front shocks. good day!
April 8th, 2010 11:53 PM #5
pumunta ako sa AXL sa may shaw yung tapat ng babyland..close kasi yung goodyear..
sabi nila ok naman daw yung toe and camber, ginawa niya ay allign lang..
pero walang nagbago..can you recommend me shop na may laser allignment..
yes higpit naman mga bolt, i check myself after nila kabit.
April 8th, 2010 11:55 PM #6
April 9th, 2010 02:38 AM #7
the toktok sounds when you turn left or right might be
1. Velocity
2. Bushing
3. Tie rod end
- Nov 2009
- 456
April 9th, 2010 07:32 PM #8Any Goodyear Servitek centers merong laser allignment. Regarding the strange sounds sa suspension, bring the car to Sprint in Banawe. Dun ko dati dinala yung '96 Civic ko nung may tumutunog sa may bandang harap. Nagpasama ako sa mekaniko nila at nag test drive kami para madinig nya. Alam nya kaagad kung ano dapat ayusin, turned out na may inadjust lang sya sa steering mechanism ko sa ilalim, cost me just P100.
Di ko sure kung same din ang problema ng ride mo pero I think its worth a shot for them to have a look. Coming from Quiapo turn right at Banawe. First corner to the right dun sila located.
- Apr 2010
- 3
April 20th, 2010 04:34 PM #9Baka makatulong tong video, medio commercialize nga lang. please browse my facebook on suspension kit, http://www.facebook.com/home.php#!/p...19&ref=profile
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
