Results 1 to 13 of 13
    i was told yesterday na may surplus OM Emu and Bilstein shocks at a local surplus shop in Angeles city. mga P2th each daw.
    comment?
    for your reference part # for your LC40 for OME front N41/N51 rear N89/N95. first part # firmer ride, for increased weight eg. bullbar, winch. max lift 2".
    umm...baka kce hindi na tumagal eh..but the price is reasonable enough.
    Given that its surplus, maybe they should price it a bit more lower (1.5K?)...
    It'll be a "hit or miss" thang though on getting a set that will last long or not. Given that its surplus for 4x4s (from Japan? Australia?), there is a high likelihood that it was used hard by the previous owner.
    ang tanong:
    how would you know kung tatagal pa ang shocks on the spot?
    dont know. but to check if it is still in good working condition. depress it quickly if it holds then ok. then after depressing let go, if it goes up then ok. for OME and Bilstein, and other gas shocks. try to look sa o-ring sa may rod if it is coated with oil as in basang basa, then siguro it will not last long.
    comment:: dont you think it unwise to buy surplus or used shocks? especially given the fact that you can get good brand new ones for less than half the price?
    parang nabalitaan ko dati ginagawa nila sa surplus shocks ay binubutasa and pinupuno ulit ng kung ano man ang nasa loob nun then weld the hole shut and sabi daw hindi safe ito...?
    tama ba ang sinabi ko?
    Para kang bumili sa Banawe yun mga nasa sidewalk nag nag iinstall din. hit or miss yan better buy from a previous owner whom you know, like Ungas ;)
    yes, useless ang pagiging branded nito if it aint functioning well. waste of money.
    KYB na lang. Mas mura pa.
    Jul 2003
    yup kyb. i used to buy old stock shocks for 200 each. galing sa shop na nagbebenta ng shocks na mahal.... minsan kasi iniiwan nung bumili ung old shocks. pwede na 200 lang naman. ok ito, very comfy lambot na kasi. kaya lang isang trail lang, pag uwi tumukod na yung shocks. hehe.
    Im looking for Bilstein shocks supplier for my 95 corolla, brand new or surplus. contact jason at 09153159656. tnx
    Please let me know kng san ako makakahanap. Tnx
surplus OME and Bilstein shocks
