Results 1 to 8 of 8
    mga sirs need advice
    ano ba dapat i check pag me "tok tok tok" sound paglumiliko un oto ko sa kanan at kaliwa (mas malakas pag sa kaliwa ang liko),
    pag deretso ok nmn sya wala tunog
    thanks in advance
    oto ko is corolla 97 gli (big body).
    CVT joints need replacing.
    tnx sir
    any idea kung how much are these.
    I think CV lang yun, hindi CVT. CV = Control Velocity. Not sure ako
    mga 2k yata ang isa nun. dalawa bibilhin mo, kasi left and right.
    ok tnx mga sirs for the help.
    Quote Originally Posted by blueray333 View Post
    Oops... my headache is causing me some problems.
    It's supposed to be CV joint.
    Make sure to also to check if the CV boot (the rubber thingie covering it) is not torn. This helps keep the grease in and the water/dirt out of the CV. IF the rubber CV boot is torn, have it replaced as well.
    Oct 2009
    All of the above are right, it is the outer CV Joint, that are making to tok-tok sound, regreasing it will not remove the sound, it must be replaced. I will cost you less than 1K for each in banawe.
"tok tok tok" sound when turning right & left
