Gano kadalas ba dapat magpa wheel alighnment for a 2000 model and up sedan? Its my first time to have my car’s wheel alignment checked at Shell and rapide – both are in magallanes makati. Yung diagnosis sa shell under the car ok naman except for the front alignment daw.. tapos may check sila electronically para sa camber daw, ayun may problema din daw. So in effect yung alignment sa gulong sa harapan will cost me 450 plus the camber sa hapap din costs 2300. Then I went to rapide to double check, sabi sakin kailangan nga daw pa align and dapat daw 4 wheel alignment since mga bago car daw ngayon dapat parati apat na gulong. Ang problem lang with rapide ang dami daw kailangan paayos sa ilalim bago daw nila iaalign. So in other words di nila aalign yung wheels ko pag di ko pinaayos yung mga problema. In fairness to rapide, they only charge 1300 for the wheel alignment and with camber na daw if necessary. Di ko na tinanong yung iba charges nung sinabi nila na kailangan paayos sa ilalim since I think na di pa sya kailangan paasyos.
Kailangan ba talaga 4 na gulong ang papaalign kahit na 2 lang ang problem like what rapide claimed? Tama lang ba price? Saan ba marerecomend nyo na magaling, maayos, at reasonable ang price ang wheel alignment? I heard you need to align your car 2-3months is this true? By the way, my car is wearing a 17” mags and and slightly tick tires. Help naman guys. thanks
