Results 1 to 17 of 17
    Hello po,
    My front driver side tire, parating lumalambot.
    Stock Hankook of 2.5 yrs old Getz.
    Nung tiningnan kung me singaw o butas, walang nakita.
    Nilinis lang, applied some kind of oil sa rim. Was ok for a week pero bumalik din.
    Another thing, hindi nababawasan right after gamitin. After several hours na naka park pag nag check ako dun bumababa or when I check in the morning dun umaabot pa ng 15 to 20 psi.
    Any help would trully be appreciated.
    Salamat,
    EJ
    Nov 2007
    sir baka sa pinaka pito sumisingaw?
    meron singaw yan, hindi bababa yan kung wala. check mo maige pati pito, sa rim at kung me naka tusok.
    baka may pako na nakabaon pero mahirap makita... pinakamabuti dalhin mo sa iyong suking vulcanizing shop para ma-confirm.
    Possible ba na me pako yet walang bubbles pag nilubog?
    Nov 2006
    Akala ko kung ano na yung parating lumalambot, Valentines pa naman
    Quote Originally Posted by hominid View Post
    It is possible na medyo mahina ang bubbles pag inilubog or mahina ang pressure of the tire, try to increase it to really see the leak.
    you may not notice when you're on the run because the pressure in the tire increases when it is hot, so when you park your car then that's the time it cools down and baka sumingaw na ito when it cools down.
    Pano po fix pag sa RIM? I was told na me adhesive daw na pede ilagay. Hirap naman akong maghanap ng meron d2 samin.
    tulad ng nasabi mo pero modelo pa yang car mo imposibleng sa gilid ng rim pero dun lang sa mga nabanggit posible manggaling kung bakit parating lumalambot check in ka lang sa ibang vulcanizing shop na medyo disente at makikita mo at titigas ulit yan ng permanente
    amf lambot-tigas ang topic
    sometimes yung mga seal/ patch na nilagay from previous vulcanizing is natanggal or natuklap.
    happened to me recently and pina gawa ko ulit.
    Jun 2006
    baka may nagt-trip sayo at pinapasingaw pag naka-park ka.
    or
    baka may micro-perforation. Look for a better tire shop.
Parating lumalambot.
