Page 1 of 3 123 LastLast
Results 1 to 20 of 43
    Jan 2004
    Nakakasira ba ng rotor ang replacement na disk pads instead na OEM ang bilhin? Malaki kasi ang price difference ng OEM sa replacement.
    You'll be safe with Bendix. That's what I've been using, no problem at all.
    Di naman, I've been using EBC pads for a year now with occassional offroad trailing.
    (no brand or unknown brand) replacement pads dont performance as well as factory pads or known brand names.
    Dec 2003
    i use bendix. i am hoping to improve the brakes without replacing the master. are there brands here are that are high performance brake pads? if yes anong brand at saan makakabili?
    Nov 2003
    EBC Brake Pads. The entry-level black stuff starts around Php2700.00. You can get it in Roadstar, Makati.
    where can you get bendix brake pads?
    Nov 2003
    you can get bendix almost everywhere. give my shop a call and we can see if we can get for you.
    also, there is no need to replace the master if just upgrading pad material. masters must only be changed if upgrading the size of the caliper since in this case the master may not be able to flow the proper amount of fluid to make the caliper pistons work properly. you will get a mushy feeling if masyado maliit yung master mo
    Jan 2004
    thanks a lot for the replies
    Dec 2003
    i won't upgrade the master. actually ayoko mag upgrade ng master. I just got a terrano which is known to have weaker brakes than an avearage car. I have read some people upgrade their master to safari. Some also changed to better pads. My decision to is change to better pads, less risky.
    Saan po ang Roadstar sa makati? (pasensiya na hindi kasi ako masyado lumalabas)
    You can also contact Auto_Xer, fellow member of tsikot for EBC brand: auto_xer*yahoo.com
    I'm using Akebono now. Though I usually use Bendix.
    Aug 2003
    Bendix Metal Kings ok din sa pagpreno pero grabe daming brake dust
  14. #14
    Around how much ba pricing ng Bendix? From the entry level, Metal Kings, and 4x4? Where's a good place to get them? I saw sa ProWheels, pero order basis eh. They don't have in stock.
    Kung AUV, dapat ba yung 4x4 na, or ok lang yung entry level?
    Bendix MetalKing for my AE111 corolla costs between P1300 to P1600 for the front set.
    Note: metalking pads needs a little heat up time to get to their optimum operating temp. Before that, it doesn't bite as much.
    Nov 2003
    if you need EBC's gimme a call. i have sets for passenger cars as well as for 4x4's
    Would you have the price of EBC's for a Nissan Frontier 2.7 4x2 (single piston)?
    Nov 2003
    i'll pm you the prices now
    Mar 2003
    sa rapide lifetime warranty nila sa brake pads 'yun nga lang kailangan ipa-reface mo rotor mo sa kanila. metal king din gamit nila.
    pwede niyo rin i-consider R-Spec brand na disk pads, last year pa ako nagpapalit sa ride ko on all 4's at hindi naman nag - i-isqueek
Replacement front disk brake pads
