Questions lang po for possible cause at effects. Recently po kasi yung car pag nearing 70 kph nagkakaroon na po ng vibrations sa steering wheel. yung parang umaalog na sya. pag nagsloslowdown naman po ako, nawawala yung vibrations. Yung vibrations po sa steering wheel, parang pag umaalog na mabilis left and right. mas mabilis yung car mas lumalakas yung vibration. napansin ko po pag nearing 70kph. hindi naman po ganun yun dati. iniisip ko lang po na, somehow para maprevent na rin ako mgapabilis ng takbo pero dapat malaman din kung ano talaga prob. ano po kaya may cause nun? anong part po kaya. ano kaya possible danger kahit magpatakbo below 70kph?
ganyan din po problema (wheel balancing) ba pag kunwari eh 100+ kph tapos may nararamdaman kang vibration sa floor area ng sasakyan (sa front lalo)and not exactly on the steering wheel? tnx.
naranasan ko to way back in college..was driving my dad's old corona 78...nagbavibrate when i shift to 3rd gear..kaya stucked ako lagi sa 2nd gear..e since wala ako pakialam ayun..nalaglagan ako ng propeller shaft(?)...yun palang mga bolts nya holding it are loose na at isa na lang ang nakakonekta...whatever...i was only 19 then..di ko alam pinagsasasabi ng uncle ko..basta nalaglag end part ng propeller shaft..nakaladkad ayaw na tumakbo ng sasakyan ko..
hmm, marami causes yan. try wheel balancing and wheel/camber alignment first, pag hindi pa rin... well something deeper na yan. things like suspension failure: bushings or sa shocks, pede din busted bearings or worn cv joint (may alog na), check mo din ung stabilizers, tire rod ends and steering rack ends.. any one of those that fails, it can cause your front wheels to vibrate and wobble. goodluck!
Dude, I also have the same problem with my SL lancer boxtype. I tried replacing the tie rod kasi worn out na rin but the same problem exist. Nag pachamber na ako pero ganun parin yung problem at 70kph to much wiggle. Kahapon ko lang pina check sa mechanic dito sa QC and guess what, yung left ball joint ko palyado na. Pinapalitan ko na ng bago left and right. Tried cruising for 100kph last night and no wiggle and even a quick brake it doesnt wiggle. Check mo lang.
Nanginginig ang buong car after 70kph. Akala ko ng engine support ang problem.
Hindi pala balanse ang rear tires ko. Pinapalitan ko lang ng magkapareho ang tire wear. Okey na! Parang bagong-bago tumakbo walang vibrations kahit na nag 140kph pa!
