Results 1 to 10 of 11
- Jun 2013
- 11
June 10th, 2013 09:13 AM #1Pa tulong naman aku sa inyo mga bossing..
ung toyota corolla 96 ko may toktok sound sa front right or left wheel.. (dko sure san banda pero ang sigurado sa harap)
Maririnig mo ang toktok sound in low speed (20kph).. sa humps maririnig mo din...
kahit sa flat roads maririnig mo.. pero kapag medjo mabilis na ang takbo wala ng toktok sounds..
san kaya galing ang tunog? pa help lng aku kc baka ma loko aku ng mekaniko..
June 10th, 2013 09:34 AM #2
Sounds when turning? Or when travelling straight roads?
Either ball joints or CV joint or both.
HTH.
June 10th, 2013 11:17 AM #4
it can be as simple as something which is stuck within the threads of the tire kung bago ang gulong.
or a wheel bearing.
dapat makita and ma check up ng mabuti.
- Jun 2013
- 11
June 10th, 2013 11:29 AM #5yes tumutunog kapag lumiliko pero mahina lng.. mas malakas ang tunog kapag travelling straight roads in low speeds..
if ball joint or cv joint magkanu kaya mag pagawa sir?.. kasama materials..
- Jun 2013
- 11
June 10th, 2013 11:33 AM #6
June 10th, 2013 11:51 AM #7
usually sir ang paunang lunas sa CV joint (if cv joint ang problema) is repack lang muna bago replace the whole joint, had the same model ng car Corolla 95 naman, and may lumalagutok sa kanya lagi, and positive ako na its coming from the CV joint, so pinarepack ko lang, and okei na, eversince hindi na tumunog, be sure lang na tanggalin yung old grease bago lagay yung bago, wag mo hayaang ihalo lang yung bagong grease sa luma.
and if balljoint naman (if ball joint naman ang problema), replace na yan, alam ko sealed type ang balljoint ng corolla, so hindi pwede yung iniinjekan lang ng grease like other cars.
- Jun 2013
- 11
June 10th, 2013 12:00 PM #8
June 10th, 2013 12:23 PM #9
If magpapa-repack ka na, use ONLY cv grease, hindi yung basta basta grasa lang. may dedicated grease for cv joints.
and also check mo nadin mga boots, pag may punit or kahit isang butas lang, palit na, maulan pa naman ngayon, dibale kung tubig lang, (thou wala din dapat makapasok na tubig), eh may kasamang lupa/buhangin, didikit pa sa grasa yun and iikot na sya ng iikot dun, gagasgasin nya cv joints mo.
- Jun 2013
- 11
June 11th, 2013 12:19 PM #10
I don't have proof but it seems like the CRV shrank from the previous generation.
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
