Results 1 to 5 of 5
- May 2011
- 5
May 5th, 2011 11:11 PM #1newbie po..meron akong Mazda3 '05 a/t, everytime na nagrereverse ako at nagbbrake yung unang tapak sa pedal malambot tapos konting release, pag tapak uli ng pedal matigas na parang di na gumana brake booster nya. check ko yung mga brake cylinders sa rear at calipers sa harap walang leak at hindi rin nababawasan brake fluid sa reservoir. possible kaya na sira na brake booster?
inputs naman po sa mga experts bago ko dalhin sa mekaniko...
salamat...
- Jul 2003
- 573
May 6th, 2011 10:08 PM #21. have the rear brake shoes clearance to drum adjusted.
2. bleed the brake fluid on all wheels.
Have a good reliable auto tech do the job.
- May 2011
- 5
May 7th, 2011 12:34 AM #3thank you very much sir for the help. i'll have it done asap...thanks again!!!
May 7th, 2011 08:58 PM #4
The Mazda3 uses 4-wheel discs.
But I agree... have the system bled and check all your brakes.
- May 2011
- 12
May 17th, 2011 01:28 PM #5sira ang brake booster or yung hydrovac, try to check this shop if you are near, they have a map, they are very much experienced in underchassis issues
http://www.sulit.com.ph/index.php/vi...+SPECIALIST%29
It will probably depend on the design of the battery casing in the vehicle in question. Teslas...
BYD Atto 3
