Results 1 to 14 of 14
    Guys reasonable ba ang price nung nag pa ayos ako ng pang ilalim ko..parang duda kasi ako sa mekaniko at shop nya..this is along Marcos Hiway Cainta. feeling ko naisahan ako eh...help, i need your opinion, para maisama yung shop na to sa mga SCAM na dapat iwasan...
    Toyota Gli 2000, Lovelife and ride ko....
    Parts
    1 pc CV joints outer (replacement japan) = 1,800
    1 pc wheel bearing (japan) = 700
    1 set bendex brake pad = 800
    2 Pcs Suspension Bushing = 520
    Machine Shop Works
    2 pcs Disk brake reface = 900
    2 pcs Suspension bushing press out and In = 500
    1pc wheel bearing press in and out = 250
    1 Cv joints mounting = 250
    Labor cost
    for suspension bushing works = 400
    for Cv joints works = 200
    For brake pad Works = 200
    for wheel bearing works = 200
    [SIZE=4]
    TOTAL EXPENSES = 6,750
    [/SIZE]
    From your billing, you didn't just had your CV joint replaced. You also had your brake pads replaced, wheel bearing as well, brake rotors resufaced, and suspension arm bushing replaced.
    That is more than just CV joints, buddy.
    The bill is just right.
    May 2007
    That is more than reasonable. Go back to that place and give them at least a bucket of KFC and a soda just to say.... thank you.
    Jun 2006
    Yeah, mura nga e.
    Sep 2008
    mura yan brother... had almost the same things done on my b12, and it costed me, if i'm not mistaken, around 8500.
    did it fix the things you wanted done on your lovelife? kasi kung nde, mahal yun!
    Apr 2005
    Mura na yan bro. If it solved your problems, sulit na!
    okey na okey na ang charge sa yo bro , kailangan magrecommend ka ng mga kakilala mo sa shop na ito .
    this shop is a real damn honest indeed, and they installed not just parts from nowhere , these are all quality quality parts !!!
    saan ka nakabili ng cv joint kit?
    actually, mura yung price. may brake pads ka na tsaka bearings, may refacing ka pa tsaka bushings.
    WOW1..talaga?..nakamura ako sa kanila?..in fairness naman mabait at honest yung mekaniko nila,saka naayos naman lahat ng sira ng ilalim ng oto ko...
    sabagay sa unang tingin pa lang nya at sa sound pa lng , alam nya na agad yung sira....hindi tulad nung una kung mekaniko, lahat na ata pina kialaman, wala pa rin nangyari.
    naayos naman at nawala yung " tok tok tok" sound sa ilalim ng car, nawala rin yung mga squeek at weird sounds na hindi naayos nung mga previous mechanic ko.
    sige recommend ko sila sa inyo...isama natin sa listahan ng mga magagaling na shop sa furom..
    The place is Petron marcos hiway, cainta..lapit sa sta lucia mall...si mang manny ang nag ayos...sinamahan pa nya ako bumili ng parts sa labas..para daw makamura pa ako...na totoo DIN pala.
    kung may problema kayo sa mga suspension sa oto nyo..punta lang kayo dito..PETRON MARCOS HIWAY.
    Quote Originally Posted by rhymond View Post
    Parts
    1 pc CV joints outer (replacement japan) = 1,800 1700
    1 pc wheel bearing (japan) = 700 (front RH) 750
    1 set bendex brake pad = 800 750
    2 Pcs Suspension Bushing = 520 500
    Machine Shop Works
    2 pcs Disk brake reface = 900 700
    Labor cost
    for suspension bushing works = 400 350
    for Cv joints works = 200 350
    For brake pad Works = 200 300
    for wheel bearing works = 200 350
    [SIZE=4]TOTAL EXPENSES = 6,750[/SIZE]
    5,750 total
    The price you mentioned is reasonable enough. Im just comparing my expenses when i brought my car (sentra Series2) sa Banawe QC (total price in blue text).
    Feb 2009
    is this the one near E. De Lapaz?
    Nov 2007
    Quote Originally Posted by josm View Post
    akala ko naman under the mango tree yung shop na sinasabi mo bro. PETRON pala eh mura na nga yan tas sinamahan ka pa pala bumili parts pano ka pang maloloko sa parts pa lang kasama ka hehehe....
I spend Php 6,750 just to replace my CV joints
