Results 1 to 11 of 11
    hi,
    got an alignment this afternoon.
    new shocks, new springs, bearing type strut mounts perfectly ok
    front:
    caster lh 3.5
    caster rh 2.7
    camber lh 0
    camber rh 0
    toe lh 0
    toe rh 0
    rear:
    camber lh -0.7
    camber rh -0.7
    toe lh 0.15
    toe rh 0.15
    thrust angle 0
    can anyone explain the possible cause of why caster is like that above? left caster is within tolerable range, but right caster is way out of range
    Aug 2004
    You hit something hard enough with the right tire to either bend the strut or knock the shock mount out of alignment... or something is loose and needs replacement.
    Feb 2009
    what vehicle is this? make, model, year? what type of front suspension?
    Dec 2009
    I think i have the same problem..Distance of the the tire from the fender is lower on the left side.I thought the problem we're the coil springs.Installed new one's but still has the same problem.Is this also connected with caster alignment.If so, what are possible solutions to this problem?? This problem is on my 98 civic vti..Please please please anyone help me out.
    Aug 2004
    Quote Originally Posted by jumz666 View Post
    From what I know, that's normal for that kind of Civic... they're built to Japanese spec, where the driver is on the right, so left-hand drive Civics sit with the right side slightly higher.
    You can check the Honda Club Philippines board for a more detailed explanation of how this is... I don't personally know if it's the spring, the spring mount or something else.
    Dec 2009
    It wouldn't be a problem if it was "SLIGHTLY" higher but the things is there's about 2-3 inches difference & i can tell most of the weight of the car is on the left side..When conrnering at curves or hitting pot holes having 3-4 passengers on my car the left rear tire gets hit & grinds the fender while the right side doesn't experience that problem..What really sucks is i've bin spending money by trying to get this fixed but still no progress.I changed coil springs, shock absorbers, bushings already coz according to the mechanics these are the most common solutions to the cars problem.I really believe the alignment is off but i don't know w/c part to align.
    car is mitsubishi lancer 2000 (ck) aka pizza.
    front suspension is macpherson
    Feb 2009
    Quote Originally Posted by spyghost View Post
    check the length of the control arm strut rod and check the strut rod bushings for wear, softening due to oil contamination. if the vehicle had been subjected to considerable impact, have the chassis pull-aligned first then have the caster adjusted using the strut rod length
can anyone explain why my alignment is like this?
