Front Tires lang pinalitan ko, ok lang ba? sabi kasi nung mechanic ok pa yung rear tires ko. kia rio 08 model. same size naman.. pero now yokohama yung harap, tapos yung stock hankook yung likod.. ano ma aadvise niyo mga boss?
[SIZE="4"]REMINDER: do not post messages in SMS/TXT shortcut format.
Read the RULES.
Ignorance is NOT an excuse.
Repeated offenses will lead to banning.[/SIZE]
ok lng yun, yung importante laging mas bago yung front tires kaysa sa rear.
kung rear lng naman yung papalitan mu ilipat mu na lang yung front tires mo sa likod at yung sa harap na lng ang palitan.
there are some who are saying na mas safe kung ang tires na mas malalim ang threads ay nasa likod nakalagay.
ang importante ay ang by pair ang palit.
Kung kulang pa budget okay lang iyong sa harap muna at pag may budget na iyong likod naman na parehong brand na rin sa harap.
Pati nga rin ako two tires at a time lang kung magpalit, for budgetary reasons. Usually mas mabilis mag-wear out yung front tires ko kesa rear tires.
Makuha ko lang yung separation pay ko, I'm going to have all of my current tires replaced, kasama yung spare. Phased out na daw kasi yung stock tires ng sasakyan ko, so I'll have to refresh all five tires with new ones.
parang gusto ko narin bilhan tuloy yung likod.. sigh ang gastos ng gulong..
It would really depend on the situation. If the failure is traction, then it would be best at the front. But for tire blowout, the newer tires should be at the back. If the front tires blow out, you can still steer and be in control. If the rear blows out, it would be out of control. Marami na din nangyari sa star toll na rear tires nag blow out and the vehicle turned upside down..
No. Always, always, ALWAYS put newer tires on the rear axle.
This is the advice of experts, the advice of tire manufacturers and the advice of car manufacturers. Without exception.
Whatever car you're driving, having bald tires in the back means a spin-out.
Trucks spin if they have bald rear tires. Jeeps spin if they have bald rear tires. Front wheel drive cars spin if they have bald rear tires (from personal experience).
Bald front tires? Braking distances get longer, but you can still stop. You have more understeer, but it's better knowing you have a lack of grip than thinking you still have control and only finding out that isn't true when you're sliding sideways across the road with a ten ton truck barreling towards you.
Now, you'll want to swap your worn tires around when you rotate, but if your tread depth is below 4/32nds of an inch, you should always have the worse tires in front to provide for better traction in the rain.
