Results 1 to 2 of 2
    Feb 2003
    hi peeps! magkaiba ba itong dalawa? anyways pano mo lalalaman kun sira na suspnsion busings mo and shocks?
    magkaiba.
    Ang bushings is usually the rubbers that are in between the metal parts of the underchasis or the underchasis parts like your shock absorbers. It sometimes look like a rubber donut or a rubber washer. Pagworn-out na ito, meron kang maririnig na "tok" or "tag" na sound or a metal-to-metal contact sound. Lalo na kung nasa lubak ka. Some worn out rubber bushings sa front could cause "misbehaviour" in steering.
    Ang shocks na sira naman would show some "oil-leak" sa tube ng shocks (if oil filled). Or when you push down the side of the car where that shock is located mabagal ito mag-spring back up or mag"bounce" effect sa spring back.
confused between shock absorber ang suspension bushing
