Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Mar 2005
    Recently nag stuck up yung Front Driver side ko na brakes and ang culprit is yung sliding pin is madumi na and wala ng lubrication. Kailagan ng gamitan ng martilyo para matanggal yung pin. Nilinis lang at nilagyan ng Ordinary Grease then OK na.
    Nabasa ko kasi sa Net Welcome to guzzle's Front Caliper Slide Pin Upgrade Web na dapat pala hindi petroleum grease ang gagamitin pang lubricate ng sliding pin. Saan po ba makakabili ng High temp na synthetic brake Grease??
    And also kung may nabibili po ba na rubber boots lang na cover ng sliding pins?
    Yung car pala is 2004 Rav4 1.8 MT
    Mar 2005
    Saw a youtube vid din pala
    baka butas na yung rubber boot.
    Silicon or Ceramic Grease. Nakabili ako nyan dati sa Handyman. Selected automotive shops also have that.
    Mar 2005
    Thanks try ko maghanap sa mga malls neto. Kaya kaya matanggal ng Brake cleaner yung existing petroleum grease na nilagay sa pins?
    Mar 2005
    Tried kanina sa Handyman, ACE sa Festival mall and True Value sa ATC wala ako nabili. Nag stuck up na naman preno so binalik ko sa mechanic. Sira na yung rubber boot na naka kabit sa may loob ng sliding pin (hindi yung cover). Nung tinanggal yung rubber boot bumabalik na ng maayos yung sliding pin.
    TS, update us san ka makahanap ng brake grease.
    also, is this the same as anti-squeak paste na ginagamit sa brakes?
    Aug 2006
    may nakita akong mga rubber boot sa Gant at sa M7
    Jun 2005
    afaik meron super lube distributor, yung white synthetic grease sa kalookan. cheaper pa than buying online (sulit.com.ph).
    Jul 2010
    In concorde megamall they sell Cyclo Silicon Grease for brake components. I a bit expensive I think but its much better than ordinary grease.
    TS, nakahanap na ako ng synthetic lithium grease.
    Top1 brand. meron nito sa DIY store. try to check at ace or handyman nalang.
    May 2009
    meself uses white lithium grease (sprayable)....3-in-1 brand.
    AFAIK available nga yansa mga autoshops. Maganda yan, I've been using that ever since I had a car.
    Mar 2005
    Saw that grease sa mga autosupply. Read some article sa net hindi din advisable yung lithium grease dun sa rubber parts dapat talaga silicone based like yung permatex sa previous post.
    Aug 2017
    High temp grease made usa
    Sent from my SM-J700H using Tsikot Forums mobile app
    Aug 2017
    170 only
    wheel bearing grease will melt and might damage the rubber boots for the brake caliper guide pins..
    Jan 2010
    That's forum free commercial advertisement.
    Know your products before erroneously prescribing
    May 2017
    Meron na kaya nabibili na Bendix Synthetic Brake Lubricant?
    http://www.bendix.com.au/sites/defau...achet%20HR.jpg
    Sep 2012
    Quote Originally Posted by maculet View Post
    For bendix I'm not sure.
    Pero if you can consider another brand, mas madali pa maka kita ng Wurth
    Sent from my ASUS Zenfone 3 using Tapatalk
Synthetic Brake Gease. Saan meron?
