Results 1 to 3 of 3
    Jan 2010
    pa help din po.. naninikit ulet un brake ko.. kakapalit ko lng ng surplus na hydrovac last year.. kaka pa overhaul lng din ng brake ko..na brake bleed n din..last december tpos ngayon naninikit ulet.. ngayon nagpalit ako ng caliper kit.. pero kumakapit prin un brake sa left front wheel ko.. master na ba ang sira or un hydrovac ulet ??? help nmn po guys
    Oct 2009
    From what you have said, iisa lang brake ang naninikit at yun ang front-left brake mo, kung ito lang ang naninikit, try looking at the flexible hose connected to the caliper kit, it could be partially clogged. Applying brake to this partially clogged would be easy for the fluid to pass through because of the high pressure, but on return, the fluid will not pass through for it cannot overcome the clogged. Thereby freezing you caliper.
    Jan 2010
    thanks.. napa adjust ko un hydrovac then ok na siya.. tukod daw kasi mxado un.. napansin ko naman na un front left tire ko nagpupulbos un brakepad pero un kanan hindi.., mbilis dumumi un rims ko sa side na yon?? ano kaya yon problema??? sabi nang napagtanungan ko normal lang daw yon?? any suggestion??
naninikit un brake
