Results 1 to 5 of 5
    Feb 2003
    guys i was wondering kun mas isa lang ako nagdadrive straight yung takbo car ang straight yung stering wheel, pero kun may sumakay sa pasahero sa kanan ko... kumakabig na yung car sa kanan....(mga 150 pounds lang katabi ko)
    ...does weight affect the car alignment?..sad to say sa honda city 2003 ko ito nangyari?..
    Jul 2004
    i have the same problem though kumakabig talaga ito kahit magisa lang ako. i had the wheels balanced and am supposed to have the camber adjusted and the wheels aligned. malas nga lang at sira yung pang align ng servitek.
    Sep 2004
    weight may have an effect on your car steering, but 150 lbs is not much of a factor.
    Feb 2004
    Ensure your tires are all properly inflated (to the manufacturer's recommended pressures) all around with a reliable tire gauge. If the car starts to pull to the left afterwards, then you'd have found the real problem.
    check your tire pressures weekly.
wheel alignment problem...
