Results 1 to 11 of 11
    tama po ba sabi ng mga mekaniko na kapag nagpalit ka ng springs ay dapat pati shocks na rin? matagtag na kasi po ang sasakyan ko...'96 honda civic..andaming pinalitan na like stabilizer link, tire rod at mga bushing saka rack end. Kaso matagtag pa rin siya...Nagplaplano na ako palitan yung springs since di pa siya pinapalitan since binili namin back in '96. Yung shocks niya di pa din napapalitan...ano po kaya?
    Jan 2009
    Your suspension won't get any stiffer with old springs. In fact, when the spring has reached the end of its useful life, it tends to sag and ride height would usually become uneven. As long as the ride height is still within specs, there's nothing wrong with the springs.
    The dampers on the other hand can either get stiff (lubrication has dried up) or bouncy (leaking oil or gas pressure).
    Start with replacing the dampers first since they're due for replacement anyway, and then see if it will make a difference.
    Aug 2004
    The chances that you'll need to replace the springs are lower than the chances that you'll need to replace the shocks. Change the shocks. If the ride improves, good. If it doesn't, change the springs, as well.
    +1 to Niky, shocks first before springs. unless springs show signs of deterioration like rust and cracks, replace them simultaneously with shocks to save on labor. naputulan na kasi ako ng front spring before.
    Aug 2005
    i think weary na rin ang shocks ko..
    same model civic 96 a/t
    tukod na daw sabi ng sumakay sa akin
    so i think 4 na ang palitan.
    napagipunan ko na din.
    wat kaya maganda brand?
    san maganda bumili?
    san ipakabit?
    im from proj.4 qc.
    Jun 2009
    Quote Originally Posted by bonghernz View Post
    san maganda bumili?
    san ipakabit?
    im from proj.4 qc.
    Konting info lang from experience,
    Nagpalit ako recently ng mga dampers ko for crv 2002 model, sabi ng mga shop wala daw kayaba na available para sa modelo ng auto ko, so I had to settle for another brand. Gustuhin ko man bumili ng original e sobrang mahal, 7500 yung sa harap per piece at 5500 yung sa likod. So sinubukan ko nalang yung inalok nilang brand, Ginza sa harap. Kaso out of stock yung pang likod, kaya ang binigay sakin e Paraut na brand. Sinubukan ko na rin since no choice, kulang ang budget ko.
    Yung Ginza na brand, parang sister company ng Monroe. Yung Paraut naman, parang gumagawa ata ng mga OEM parts for Subaru. Yung GInza na nabili ko ay ok naman so far, pero syempre iba parin ang ride ng original. Parang pakiramdam ko di tatagal tong Ginza ng more than one year. Pero yung Paraut, NIGHTMARE! After 2 weeks palang, may langitngit na. And worse, ayaw pa palitan nung shop na pinagbilhan ko, kasi daw ganun talaga ang replacement part. Mga ulol talaga, san kayo nakakita ng damper na walang isang buwan e maingay na? Dapat daw one week palang binalik ko na. Anyway, para wag na kayo mabiktima tulad ko, Please DO NOT BUY FROM NISPARTS banawe, yung nasa kanto ng quezon ave at banawe, katabi ng union bank. Sobrang poor customer service. Nagbebenta sila ng nissan and honda parts.
    My suggestion: mag KYB nalang kayo or some other brand na kilala, and make sure may warranty sila. Wag nyo na tipirin dahil sasakit lang ulo nyo gaya ko. AND AGAIN, DO NOT BUY FROM SHOPS LIKE NISPARTS NA WALANG WARRANTY kahit na obvious naman na defective ang binigay nilang part.
    Apr 2005
    Quote Originally Posted by CRV280 View Post
    Sorry to hear your story. =(
    I have the same car and suspension prob. Medyo research mode na ko coz badly needed to replace my shocks.
    Sa isang thread Ginza rin recommended:
    http://tsikot.yehey.com/forums/showt...30#post1309730
    Ginza ba pinalagay mo on fronts and rears? How's the ride so far after a few months? Matagtag pa rin ba?
    And san ka nagpakabit?
    Thanks in advance, Sir!
    I'll appreciate any inputs.
    san maganda bumili?
    san ipakabit?
    im from proj.4 qc.
    Try Massive along Jose Abad Santos near Hundai Car Dealer
    They are more cheaper regarding KAYABA SHOCKS . They are the supplier of KYB shocks in Blumentrtt and BANAWE auto supply. It is also across WILSON AND JACKSON Auto repair shop.
    Apr 2005
    I called massiveParts and was told that the KYB shocks for CRV is still under development. Probably next year pa raw magkakaron if ever. =(
    Any shops that you can recommend?
    tanong na din po ako dito.
    I had my shocks 'filled' from Zee yung shop na along aurora ata yun.
    Then I replaced my front springs from its lowered state back to its original springs kasi lagi nasayad sa mga humps at kawawa sa mga malalim na lubak sa daan patungo sa bundok na tinitirhan ko.
    Issue/Question:
    Pag nadaan ako sa may rosario flyover going to pasig, may mga dugtong yung road dun dba, ang lutong ng kalabog sa front part ng kotse.
    In your own assessment, does it have anything to do with my change/development in the shocks and springs??
    o baka nman tlgang ganun lang ang epekto sa mga ssakyan dahil sa daan lang talga?
replace springs and shocks?
