Results 1 to 7 of 7
    Jun 2010
    PROBLEM:
    tuwing binubuksan ko aircon...medyo bumababa idling...and normal naman yon talaga...pero...paminsan minsan...kapag naka neutral...bumababa pa onti onti..den normal nanaman...tatakot lang ako baka kasi kapag tumagal...eh mamatayan nako...with or without lights on...ganun parin...
    HELP!nu pa problema ng sasakyan...Civic 98 model
    check this:
    alternator charging
    battery load and charging
    spark plugs
    Aug 2009
    check car's vacuum and actuator.........
    Try searching tsikot forums bro, there are a lot of topics relating to this. Hint: try searching "idle air controller valve"
    Jun 2010
    Thanks guys,check ko lahat ng sinabe nyo.salamat.
    Pare tama si boss mazingerZ "idle air controller valve (IACV)" yan. Try cleaning that with carb or brake cleaner. Pati ung air filter linisin mo or pa-vacuum. Have the same problem with the same car 98 civic vti last month lang. Search mo lang sa forum or with the help of GOOGLE.
bumabagsak idling tuwing bukas aircon
