Results 1 to 5 of 5
    Hello mga katsikot.
    tanong ko lang kasi pag nadaanan ako sa asphalt or makinis na daan umiiyak or may squeaking sound ang mga gulong ko sa harapan. ano kaya problema nito? miss alignment?
    nag start lang eto nung tinanggal ang mga gulong sa harapan para ibaba ang transmission para palitan ang pressure plate, clutch disk at releasing bearing. ang oto ko ay luma na, corolla bigbody XE 1993.
    Thanks.
    Feb 2009
    Quote Originally Posted by wiggler View Post
    Hello mga katsikot.
    Thanks.
    the front tire toe might have been altered. feel the tire for feather edging and/or check for diagonal scratches on the treads of the tires.
    if that happened, need camber and alignment na? pero bat ganun okay naman before.
    yes, it needs camber and alignment.
    nangyayari yan due to the bad roads dito sa pinas.
    Feb 2009
    the camber and caster is usually not adjustable on your car unless you have an aftermarket upper strut mount. only the toe has the possibility of being out of adjustment after the clutch job.
Front Tires Squeaking Sounds
