Results 1 to 15 of 15
    Oct 2003
    Ano kaya problema when there's a noise coming from the right front-wheel at ~50 kph and above. The noise gets louder with the speed, when travelling straight. Nawawala lang yung noise when the road curves to the left or when speed is below ~50kph. Marami nagsasabi na wheel bearing needs replacement daw. I think tranny is not related because the noise doesn't change even if I shift to neutral at high speed.
    Other suspected an oblong tire but I just replaced all my tires and the problem still exist. Ride is '99 Accord.
    Thanks for any opinion.
    Aug 2003
    maybe camber? or wheels not balanced? even with new tires you have to balance the wheels.
    wheel bearings needs repacking or replacement na.
    Nov 2003
    yep,prob the wheel bearings lang yan!
    i would've said something about your tires.. but since sa isang side lang..malamang bearing nga yan...
    OT: speedy.. may sticker ba yung shop nyo?.. on my way to the office this morning i happen to see an EG civic (pearl white ata kulay) entering the meralco compound with a SPEEDYFIX sticker at the back.. ehehhe. wala lang. naalala ko lang yun handle mo dito sa tsikot.. ehehhe
    if bearing is the culprit, papalitan mo na both sides
    yup pag nawawala habng kumakabig ka eh maluwag na bearing mo. papalitan mo na po agad yan
    Oct 2003
    yup tama bearing yan may konting tama n( malapit n bumigay)
    Nov 2003
    yep, may sticker yung shop. i give to all of my customers
    sir bearing lang yan...parang umuugong yung sound pag sira na bearing or natuyuan ng grasa..
    palitan na po ninyo both sides..
    Oct 2003
    Thank you sa lahat ng nag-reply.
    Indeed the right-front wheel bearing was bad.
    The wheel knuckle was brought to a machine shop to take out
    the bearing from the hub.
    Problem solved!
    Thanks.
    Nov 2003
    guys! i have the same problem sa likod naman nangagaling ang ingay. It started when i replaced the old tires with thereserve tire na relatively luma na rin. Pero yung noise sound like bearing rin nga problem but i tot it allstarted when i replaced the tire d kaya tire lang yun? how can i find out pa check ko na ba dapat sa Mechanic ko?
    Apr 2004
    ize_9 well the only thing you could do is try exchanging the positions of your tires if the sound still exist then bearing nayun...
    try mo mona suggestion ni snyc3 - may mga gulong talaga na pag upod na e nag-iingay!
    OT (sensya na po)
    Sir speedy - bat nung nag pa change ako ng timing belt, di ata ako naabutan ng sticker! :D
    Nov 2003
    sorry dude! balik ka nalang sa shop and ask for one. minsan kasi nakakalimutan ng guy ko dun to give them out.
    or, you could also wait kasi i'm meeting with a guy to design the 2nd batch of stickers na coz mga 10 pcs nalang natira dun sa 1st design
Wheel Noise at High Speeds
