Results 1 to 4 of 4
    Hi guys, I was driving along Kalayaan Ave this morning when the knocking sound started. Then from full stop tapos mag-accelerate, hindi siya rinig, but when I step on the brakes, that's when it starts. Sabay siya sa pag turn ng axle. I tried slowing down to hear it clearer and found out it hits two times per turn ng axle dun sa ilalim. Not sure kung saan tumatama. It got louder after 5mins of drive but not that alarming.
    Then on my rear left tire, I'm hearing squeaking sound. Also not sure where this is coming from. The brakes and mags are not touching each other either.
    These started after i changed my mags to 16s then 50 series tires a week ago. No rubbing issues naman.
    Later dadalhin ko dun sa nagkabit to check the problem. Baka lang kung ano ano sabihin kaya I wanted to get an idea kung ano yung problem based sa experiences ng fellow tsikoters.
    TIA!
    Check mo muna brake mo baka naninikit ang pad sabi mo pag nag brake ka doon mo naririnig . Subukan mo muna na itaas iyong gulong sa likod tignan mo kung saan nangagaling ang tunog. Pag inikot mo gulong kung sobra higpit hindi maikot magiinit agad ang brake pad mo .
    sige try ko din yan mamaya, kasi pansin ko may sound pa din kahit mabagal. dati pag mabilis lang tapos nagb-brake.
    how about dun sa knocking sound, anyone encountered that one? TIA
    just to update, bushing daw yung problem. may crack na kaya papalitan na. 600 per side yung quote sakin + 600 for labor. all in all 1.8k. hindi na masama. hopefully maging ok na ulit ride ko tomorrow.
Knocking sound under the pedals and squeaking sound on tires
