kanina ko lng napansin ng inadjust ko idle kasi taas-baba ung idle tapos malakas ang vibration.
may maliit na cut ung hose going to the brake booster. ano effect nito sa brakes at sa engine? nung hilahin ko ung hose para bumukaka ung cut ng hose, namatay ung engine. nung hinawakan ko ung cut para magsara gumanda na idle nya.
Need help here...Got a problem with a KIA SEPHIA 1.5L 16V M/T w/ ABS (locally distributed)...Power brake booster seems not working properly, leaks somewhere, when pedal pressed - air breathes (sumisinga), parang delay release ng brake piston kaya overheat pads...
Help me find either brand new (OEM / replacement) o kahit surplus BRAKE BOOSTER, la kasi available Columbia Motors. Kung meron Brake Master Cylinder sabay ko na rin.
Also, advise please if it is possible to change the whole hydrovac with another model or brand (say nissan)?
