Results 1 to 9 of 9
    Apr 2009
    Just installed 17s lightweight mags on 215/40R17 Advan Neovas on my Sentra n16. Fits well, no offset adjustments needed.
    Someone told me to expect poorer gas consumption...
    Makes sense since wheels now need slightly more torque to move.
    But is the difference that substantial and the FC increase that noticeable?
    Should I be worried?
    Quote Originally Posted by isa1023 View Post
    It will have to do with the diameter of the original and new wheels and the weight as well.
    Bigger wheels would act like there was a longer pole at one end of a seesaw. So it would take more power to move the same mass. This means if you are in a stop-go type of traffic, you will need more energy to move and accelerate the car everytime.
    Weight is another consideration. In general, bigger wheels also have more weight. Or if they weigh the same, the mass is more concentrated at the outside diameter. This results in the car needing more power to accelerate the wheel itself.
    Also wider tires than stock will have more friction. This is good and bad. Good because you can steer better and stop earlier. Bad because wider tires will have more friction to slow you down as well. This is why cars designed for better fuel economy have narrow tires to minimize the friction of the tires on the road.
    Dec 2007
    Fuel consumption will still depend on how you drive, although it should get a little worse. To a certain extent, it also depends on how variable the fuel consumption is for your car.
    Going lightweight is the right way to go though. You want to reduce unsprung weight (brakes, wheels, tires, suspension etc), which is the worst kind for the car. The funny thing with lightweight wheels, however, is that they cannot account for the weight of the tires. If the tires are heavy, they can cancel out any benefit to unsprung weight brought by the lightweight wheels.
    Apr 2009
    Thanks for the replies.
    Since now Ive got 0.25 inches more in wheel diameter, wider rubber and more metal to torque up and roll, guess it's a fact that I now have to drive more prudently. So far hindi naman po noticeable yung FC increase, I hope a little bit of overinflation (2 psi than normal) could help. Matagtag na eh
    Careful with overinflation. That can result in less than optimum tire grip when trying to brake quickly.
    Apr 2009
    Noted sir.
    The tires had very minimum grip at all since they're overused, I think.
    Almost "kalbo" na.
    Treads are really worn out and Im working to replace them with cheaper comfort tires (if ever those have sizes in 17s)...
bigger mags, lesser gas mileage
