Results 1 to 6 of 6
    Jan 2010
    Hi mga sir ask q lang kung how much po ang resurfacing for each rotor first tym q po kc magpapagawa s talyer ansabi po kc s akin 550 pero mukang each rotor po daw un? Tama po ba un or 550 sa lahat na? Babae po kc aq wla po aq maxado alam s kotse andami q po kc ipapagawa like ung aircon filter dahil nde n nya kinakaya ang init lalo na s tanghaling tapat . Pero ansabi pplitan lang nman dahil baka madumi lang. And since matic po ang sasakyan q na nissan sentra gx 2006 model ung gagamitin daw po na breakpads is worth 1200 ata s pagkakatanda q dahil magandang klase n daw un at para daw s matic n sasakyan dito lang po aq magpapagawa s evangelista s area nmin nakita q po ung repsol auto repair shop does anyone knows this shop para malaman q kung ok ang review and the labor is 500 lang and magpapachange oil change light bulbs antenna and wiper ang ipapagawa q since lahat daw ginagawa nila. Pls. Advise and kung meron pa din po b kau marerecommend na other shops. And is it ok ba kung iwan q ung sasakyan s shop or need q pa bantayan. Pls pls need ur advise. Thanks
    Jun 2005
    Quote Originally Posted by crazykristine View Post
    Sounds about right imho. Medyo nasa high average yung charge nila. Malamang nga per rotor yung reface charge. Just to give you an idea, ang cost ng reface sa machine shop is 350 per side. So kung 550 per side inclusive of labor, pwede na din.
    As for brake pads, at that price, i wil settle for no less than bendix na brand. Kung hindi bendix pero ganyang presyo, i'd walk away. Lokohan na yung presyo kung cheap replacement or rspec lang.
    Yung sa aircon filter, mahina ba ang buga ng hangin? Kung mahina yung buga ng hangin pero malamig yung binubuga, aircon filter nga yan. Kung walang lamig, may leak ang aircon. Expect to spend a lot more around 5-7k siguro.
    No idea on the shop.
    mura lang aircon filter. kakapalit ko lang din. 200 pesos for the hyundai getz.
    Jan 2010
    Thanks mga sir s breakpads how much po ang bendix? An if not bendix how much usually does it cost? Nde pa po kasama yng labor hiwalay pa daw po which cost 500 php and is it ok kung iwan q ung kotse s shop or need q pa ba bantayan? Many thanks
    Jan 2010
    Ilan po b ang discbrakes ng nissan sentra gx at 2006?
    REMINDER: do not post messages in SMS/TXT shortcut format & grammar. Use proper sentenses and paragraph construction. If your posted message is hard to read, less people will read it & respond.
    Read the RULES.
    Ignorance is NOT an excuse.
    Repeated offenses will lead to banning.
Help!
