Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Oct 2015
    Nag pa align na ako sa motech. Pero sabi di makita kung bakit kumakabig paren.
    Eto ginawa nila.
    1. Align
    2. Rotate front tires
    3. Check tire pressures.
    Still kabig sa right.
    Oct 2017
    Quote Originally Posted by dieselpowah View Post
    Eto ginawa nila.
    1. Align
    Baka shocks? Or tyres?
    Sent from my SM-G930F using Tapatalk
    odometer?
    brake caliper pin lubricated? it could be sticking brakes...
    ball joint on the tie rod still ok? normal wear and tear...
    whats the vehicle in question..
    Feb 2009
    Can you identify the vehicle?
    Can you post the before and after alignment angle readings for analysis?
    If you have the needed readings (angles), it would be so easy doing diagnoses even miles away.
    Eto ginawa nila.
    1. Align
    tires might be out of round.
    you won't find out if you won't look for it.
    "un-mount the wheel and roll it on a flat concrete surface. if it won't roll straight, then it is probably out of round."
    errr... has the vehicle been in a significant accident that might have affected its suspension or body geometry?
    Feb 2009
    There is a distinction between leading or drifting and pulling. Google the differences.
    When does the symptom happen a. during acceleration
    b. during decelaration or braking
    c. while coasting?
    Oct 2015
    Car is toyota innova 2012 diesel
    Wala na yung reading. Did not got a picture of the result. Thinking it would be ok after alignment.
    It had no history of major acciden.
    Only minor scratches.
    Will try the out of roundness test.
    But i not sure if that is the problem. Because the mechanic there swap the front right tire to the front left tire. And still it steer to the right.
    On steady speed it will veer to right.
    The steering wheel turn about 5 to 10 degrees by it self.
    When stopping to a halt. Without touching the steering wheel, it rest to about 5 to 10 degree turn to the right. Same as on driving on steady speed.
    For the brake calipers. The mechanics at motech did not check it. They just align it twice and gave up.
    In the end they said "sir ganun talaga minsan di maayus dito. Derecho pasok nyo po sa casa. Pero di ko naman kayo charge ng alignment. Wala po kayo babayaran"
    Oct 2015
    Odo running at 85T km
    Oct 2015
    Motech did check tie rod no problem daw.
    Feb 2009
    There are procedures to follow and pre alignment checks prior to performing alignment angles reading and correction.
    Check tires pressure size, age,condition,wear pattern.
    Check wheel bearings for proper adjustment
    Check brakes for dragging
    Place vehicle at curb weight
    Measure ride height left and right front and back
    Check rear camber
    Check rear toe
    Check front camber
    Check caster
    Check front cross camber
    Check front cross caster
    Check steering axis inclination
    Check toe out on turns
    Check thrust angle
    Check front toe.
    Check front wheel setback
    Check steering wheel over center adjustment
    In that sequence.
    Oct 2015
    Check rear camber
    Check rear toe
    Check front camber
    Check caster
    Check thrust angle
    Check front toe.
    In that sequence.
    Saan shop po gumagawa ng ganyan check up?
    Feb 2009
    All of them are supposed to do that.
    Most shops are just posers.
    is the fender gap smaller on the rightside? it could be bad shocks or worse the right coil sagged.
    Apr 2014
    Im assuming your front tyres are of the same brand and model?
    Also is your steering wheel on centered?
    Oct 2015
    Will measure the gaps tomorrow. To see if the shocks sagged.
    The tires of same type and wear pattern.
    Jul 2013
    Eto ginawa nila.
    1. Align
    Dati na ba yung kabig nya? Or ngayon lang?
    Sent from Zenfone 3 on Tsikot mobile app
    Oct 2015
    Recently lang. 4th quarter ng 2017 ko napansin na kumakabig.
    Feb 2009
    Check post # 6
    Jul 2013
    Ok. Try mo pag palitin tires mo sa harap (right to left and left to right)
    Feb 2009
    If I'm not mistaken, your innova has solid rear axle with semi elliptical leaf springs.
    Measure the wheel base left and right.
    Sometimes the center bolt of the rear springs slide or break resulting in a thrust angle.
Car is turning to the right.
