Results 1 to 5 of 5
    Oct 2013
    Hi mga Co-Tsikoteers
    Magpapa advise lang ako regarding sa brake problem ko.
    For the 1st two hours of using the car, ok naman sia, wala kang maririnig, but after that, magstart na magkaroon ng screeching sound sa driver side-front.
    Pero pag nakapagpahinga na, ~1hr, ok na ulit.
    Tiningnan ko ung brake pad, makapal pa naman and walang scratches ang rotor. Ano kaya possible na reason dito?
    TIA!
    Feb 2009
    Please provide the following info:
    Production year
    Make
    Model
    Mileage
    Last thing relevant thing done prior to the start of the symptoms.
    Jan 2011
    Akin po 2k ang mileage ganito rin basta pagkatapos ng carwash kahit hindi naman malayo at matagal ang biyahe at pag hand brake.
    bleed the brake. if air bubbles come out then that should solve your problem. air expands when its temperature goes up causing the brake to bind. that is why it returns to normal after you rest it for a while.
    Quote Originally Posted by marion2 View Post
    brake pads are wet. ride the brakes for a few minutes to dry them. konting apak lang while moving for a few hundred meters matutuyo na. do the same after passing through flooded streets.
Strange Screeching Brake Problem
