Guys,
I just want to know the tires currently on our rides. Umpisahan ko na:
Mitsubishi Strada 2001
Firestone Wilderness AT 31 x 10.5 R15
Guys,
Dunlop Grantrek MT1 33x12.5R15
Wow! Those are some meaty tires!!! I love mean thick tires. Do you have trouble with the steering? Did it get heavier? I had the bridgies A/T's once and they're toughOriginally Posted by boybi
Hey guys, Is it true that M/T's have a hard time gripping the road when its raining?
Oh by the way, sticking to the topic![]()
D-max: Dunlop Grandtek A/T's 245/70 16
Eddie B's Explo : 245/60 17 Michellins
stock lang po ang akin:
17" x 7.5"/8.0" (front/rear) 7-spoke aluminum-alloy wheels
P225/50WR17 (front) and P235/50WR17 (rear) high-performance tires
02 fieldmaster - stock bridgestone dueler a/t 267/75/r16
05 outlander - stock yokohama geolandar G035 205/65/r16
160/65/14 high performance dual purpose run-flat BF goodrich rated W tires
nissan patrol GU
pirelli scorpion A/T
275/70 R16
eto yung website: http://www.pirelli.com/en_42//tyres/...catid=WW_SUVOF
front 145/70 R12 forgot kung anong name nung tire
rear 160/80 r12 ata yung rear cheng shin tire
Dati michellin at hankook tires ko kaso nahirapan na ako maghanap...
Originally Posted by ILuvDetailing
nope. Rear tires pa lang pala yon, eto ang front.
175/65/14![]()
run-flat tires usually have stiffer than normal sidewalls to help support the weight even if there is less than optimal pressure, albeit at lower speeds, thereby allowing it to "limp" until you could find an air pump.
Honda Accord
Goodyear NCT 3 - Front 195/65 R 15 95H
Goodyear NCT 5 - Rear 195/65 R 15 91V
Tire pressure 32
If I reduce the tire pressure to 29-30 would this make the ride softer over minor road imperfections? I feel almost every single little bump on the road... I kept the tire pressure at 32 because that is what is indicated on the door sticker.
Isuzu Fuego: BFGoodrich Macadam T/A 235/75/15
Toyota Prado: Bridgestone Dueler H/T 265/65/17
Toyota Hilux: Bridgestone Dueler H/T 255/70/15
