Results 1 to 8 of 8
    Jul 2013
    Hi guys! I need your quick advice.
    Our Innova has 15,000kms on it and unfortunately, I forgot (or I the casa forgot) to rotate the tires at 10,000kms.
    Now, my problem is complicated by the two front tires whose outer side has more wear than the inside (positive camber).
    This seems to be a common Innova problem which I noticed only after 15,oookms.
    I know I need to have the camber alignment checked.
    But my question is: Is it still safe to rotate the tires as recommended in the manual?
    It's better to put those at the rear.
    If you rotate, just do the front. Mahirap masabugan sa front.
    Jan 2011
    Same experience pero sa sub-compact at worst pa kase 20k+ na ang odo bago wheel alignment ang solusyon namin palit bagong tires tapos lipat sa likod bale yung even thread na tires na dati sa likod ang nilipat sa harap.
    Oct 2009
    iba ang rotation sa biling..
    bili ka nalang ng 2 bago saka mo ipakabit sa harapan..
    di baleng medyo luma ung nasa likuran,ang importante ung sa harapan..
    quiet ako dito..
    my gut wants to say something my brain does not want to say..
    Nov 2007
    Quote Originally Posted by Lew_Alcindor View Post
    If manipis na talaga ang tread, change tires na dapat.
    If you're getting new tires, sa likod dapat ilagay ang new tires! Common practice talaga before na ilagay ang new tires sa front but that myth has been debunked.
    here's a trusted article by tirerack why new tires should be installed sa rear:
    http://www.tirerack.com/tires/tirete....jsp?techid=52
    Quote Originally Posted by JJB View Post
    I learned something new. Thanks.
    Posted via Tsikot Mobile App
    Jan 2009
    Kung outer tread ang worn-out, check for excessive toe-in. Camber does not wear down tires as fast as an incorrect toe setting, especially 15,000 lang tinakbo.
Tire rotation with two of the tires with uneven wear
