good day po mga fellow tsikoters
honda fit/jazz ang car ko,,2003 model,,minssan nagkakarga ako ng gas sa petron ng xcs ,,,minsan sa shell ng premium gas ,,tanong ko lang po kung magkaiba ba ito ,,,pareho ba itong may e10 ?? hindi ba magkaroon ng problem sa makina..ganun po kasi ang pinakakarga ko tuwing mauubos na gas ??since pareho namang gas ito???sa ngayon mahigit one month ko na gamit ang car...so far wala pa naman akong naririrnig sa tunog ng makina,,lately lang kasi nag flush ako ng cvtf at nag change oil ,,,pure synthetic ang ginamit ko.wala na po kasing owners manual tong car ko kaya karga lang ako ng karga...
Make sure that the CVTF that you put in the transmission is the one from Honda as it is not sold anywhere else. Putting ordinary ATF will damage the CVT transmission.
As for the engine oil, weather using synthetic or mineral, always use the viscosity type recommended in the manual.
Regarding the fuel, I think only Petron Blaze is ethanol free. All the rest have E10 added as mandated by law. AFAIK, all Jazz/Fit cars are ethanol compatible.
thanks civic vti..i follow all the information you gave ,,i went to honda casa to flush the fluid of the said cvt and it cost me money to replace it ,,,pero ok lang to make the tranny long last sabi nila sa casa ...
regarding the fuel..... i used only the gas from petron with e10 mix xcs with 95 octane rating k naman ang makina thanks for the advice ,,,kaya lang napansin ko ng mapalitan ung fluid eh parang nawala yata ung gear shifting from 20k-40k dati i fell nag auto **** sya and 40k pataas ay di ko pa rin mafell ung sipa ng gear,,,may binuksan pala ung mekaniko sa casa honda ito daw ung shift solenoid at kanya itong nilinis at sinoli muli pagtapos na malinis,,, and then drive test nya ito at ok ng manakbo ,,,,kaya lang ng mag nagdrive na ko ehh ayun na nga di ko na mafell ung auto shifting gear ng car,,ano kaya ito tanong ko lang kung pwede ko ba dalahin sa iba mekaniko para matingnna ung problem ,,ayw ko ng bumalik doon sa CASSA IT COST ME MONEY thanks again for your reply
As long as the transmission upshifts at the correct rpm range, then there is nothing to fix. If you don't feel the upshift, then the new CVT fluid is doing its job well. While accelerating, glance at the tachometer (RPM gauge) to make sure the transmission upshifts at the right moment.
thanks civic vti for the reply,,,,ganito ang rpm reading ko while accelarating ..normal lang kaya to... 80kph above nasa 2000 rpm ..papitik pitik lang ng konte sa gas...sa flat surface road ...pag medyo uphill naman ..konting diin sa gas tumataas ung rpm..2300 rpm ...i feel na parang humatak ng konte ...pero huindi ako kuntento duon sa hatak ,,,,siguro mabigat kami ..bale anim kami sa loob ni honda fit....,,,konting kagat lang ang na feel ko...tanong ko lang kung meron bang dapat na iadjust sa mga sensor nito like TPS throttle positon sensor,,ung kickdown cable or throttle cable e pwede ko ba ipacheck ito,,,para kasing hindi ako satisfied duon sa gear shifting ng cvt simula ng galawin ung shift solenoid..ipakalibrate ko kaya uli sa casa...what do you think sir civic vti??? thanks a lot
Pakiramdaman mo muna ang ride ng walang pasahero. Kung di ka pa happy at kung may sufficient funds naman, patingin mo uli sa casa. Ask them to take a test drive with you onboard para madescribe mo sa kanila yung hinahanap mo na feel.
