Results 2,361 to 2,370 of 3900
Tsikot Member Rank 4
- Oct 2004
- 1,054
September 11th, 2005 11:11 PM #2361caloymd: np ! im really sure na walang problema na mangyayari dyan
September 11th, 2005 11:14 PM #2362
doc caloy: balitaan mo na lang kami kung may improvment sa fuel consumption and performance
September 11th, 2005 11:21 PM #2363
i agree with kmo, i dont think something bad will result to the change in better airfilter, otherwise, sira na pangalan ng knn. I suggest doc caloy that you replace them both at the same time para mas malaki improvement...
- Jul 2005
- 95
September 12th, 2005 12:43 AM #2364Actually gusto ko nga isa-isa ang palitan ko (whether plugs, filter, tire pressure, or gas octane) para nakikita ko kung san galing improvement (parang sa gamot, hehe -- kung madami ka binigay na shotgun approach, di mo na alam san talaga galing improvement).
Pinakabit ko yung dynamats sa front speakers, nabawasan nga ang vibration (kaso dinig pa rin yung vibration sa likod). Also found out what speakers came stock with the "premium sound system" -- 40w panasonics. Waaahhhh...
Hirap na, daming pwedeng palitan!
Tsikot Member Rank 2
- Aug 2005
- 375
September 12th, 2005 01:25 AM #2365anong magandang panglinis ng engine? dumi na kasi eh, mostly i think nagsamang alikabok at putik. hindi pa kasi ako naglilinis ng engine eh except dun sa lumang kotse.
September 12th, 2005 01:30 AM #2366
Originally Posted by erict
September 12th, 2005 10:03 AM #2367
- cover the alternator and MAF sensor with rags and plastic (just enough to repel water)
- don't power wash or use high pressure water spray.
- warm up the engine for a couple of minutes
- spray the APC + Water mixture on the engine bay, use brush to aggitate dirt and grime.
- use light running water to rinse.
- wipe down the engine, if you have compressed air then use it on the hard to reach places. Thats it. HTH.
- Aug 2005
- 375
September 12th, 2005 10:10 AM #2368Originally Posted by zeagle
- Aug 2005
- 375
September 12th, 2005 10:54 AM #2370
erict: all purpose cleaner. Try looking for Simple Green * True Value. Its Citrus based its safe on rubber parts like hoses, etc.
I would actually not go for these and recommend the Changan Nevo Q05 instead. It's a better...
