Results 2,351 to 2,360 of 3900
September 9th, 2005 01:45 PM #2351
Originally Posted by Isuzoom
September 9th, 2005 11:20 PM #2352
Car ko stock lang no hilig with bling blings mas important performance and service than looks..
September 10th, 2005 08:31 AM #2353
reminder lang. may show ngayon ang mantrade sa the fort parking lot near shell gas station. 8am to 6pm.
- Jul 2005
- 95
September 11th, 2005 01:24 AM #2355Guys solicit ko lang opinion niyo -- if you have to choose between K&N filter and iridium plugs as an initial upgrade, what would you pick? Which would afford the most improvement? Most bang for your buck?
Thanks in advance!
Matutuloy kaya yung "seminar" sa Nissan Commonwealth?
Tsikot Member Rank 4
- Oct 2004
- 1,054
September 11th, 2005 02:10 AM #2356caloymd: mas ramdam mo ang diff pag knn filter and inuna mo yung spark plugs minimal lang ang diff at hindi mo ramdam sabi nila sa milage daw pero de rin naman ganun kalaki e yung filter talaga mas ramdam so i suggest unahin mo filter then spark plugs
September 11th, 2005 08:32 AM #2357
may datung si kmo kaya filter. kung ako una muna sparks, then ebc greenstuff brake pads then k&n filter. kasi w/ the 1st 2 walang mainvalidate na warranty. i asked already sa mantrade.
September 11th, 2005 09:53 AM #2358
Ako takot pa din palitan air filter. If there will be problems with it, it will come out several years from now. There will usually be a trade-off in terms of engine wear and tear.
- Oct 2004
- 1,054
September 11th, 2005 10:34 PM #2359hmm i dont think na masisira naman yung makina just by changing the filter .... ewan ko lang kasi yun nga as ive said dati, bkit masisira ang component if all your doing is improve it? like yung filter, gusto mo lang mas free flowing at de mo na kailngan palitan lagi, so ok ang same as the spark plugs from stock papalitan mo ng iridiums which is better and yung brake pads na from stock to ebc greenstuff.. pero kanya knaya na yan hehehe
- Jul 2005
- 95
September 11th, 2005 10:39 PM #2360Thanks for the suggestions! Nung basahin ko mga comment sa australian forum nagdecide na din ako mgpalagay. La pa daw nagka-problem sa mga ngkabit nun, and most have good things to say about it. Sa Nihhon banawe available siya for 3500. Pakakabit ko bukas, hopefully makita ko din yung difference. Hehe, akala ko kasi lahat kayo ngpakabit na nun kaya hinanap ko sa banawe.
