Page 219 of 273 FirstFirst ... 119169209215216217218219220221222223229269 ... LastLast
Results 2,181 to 2,190 of 2721
    Dec 2007
    #2181
    Quote Originally Posted by btdthat View Post
    All I have read so far indicated the turbo diesel is the more powerful engine compared to the 2.5 gas so if you enjoy driving sporty and fast I think this is the engine for you. I test drove the 2.5 AWD gas and it was quick and responsive enough for me so if I end up with this I am ok. I generally drive slow and on highways I seldom go past 100 kph so the diesel might be too under utilized in my case. Per to my agent there are barely any shipments of the diesel on both CX5 and Mazda 6 so if I wait for diesel it will probably take even longer.
    Congrats pa din!!!
    Sent from my ASUS_Z012D using Tapatalk
    Sep 2004
    #2182
    2014 cx5 owner here..tanung ko lang yung remote kasi problematic
    a few tries bago mag unlock yung car. sometimes more than a minute parang wala lang.
    once naman nag unlock na, only then the remote works like normal.
    pinalitan ko na battery ganun din
    anu kaya problem sirs?
    thanks
    #2183
    Quote Originally Posted by guido View Post
    thanks
    Your remote key's batt terminals need cleaning. It'll be back to normal.
    Sep 2004
    #2184
    salamat sir. try ko
    Sep 2004
    #2185
    salamat sir. nag work na. actually more on a weak contact.
    konting unat lang nung contact points.
    share ko na rin na important yung pagreplace nung cover na meron rubber ring.
    keeps the battery in place. pag maluwag kasi nawawala contact
    #2186
    Kamusta ang FC ng 2.5? City and highway. Thanks
    May 2010
    #2187
    Ano masasabi nyo sa liquimoly jet clean tronic deep carboncleaning solution... sinasabi sa mazda greenhills na kaylangan sa cx5 ko.. 2.5 years old 24k mileage pa lang... any comment po?
    Quote Originally Posted by oxner111 View Post
    your skyactiv engine is di...
    Direct-Injection Engines ? How to Protect Yourself from Valve Gunk - YouTube
    #2189
    The proper way to thoroughly decoke DI engines is thru walnut blasting. If there is no felt drop in engine performance, I'd skip the offered service. You'll likely be paying for placebo.[emoji4]
    Mar 2004
    #2190
    Just do an Italian tune up every now and then ... cheaper and more enjoyable ...
Mazda CX-5
