Results 2,311 to 2,320 of 2561
- Sep 2015
- 7
September 26th, 2015 08:40 AM #2311Mga sir, tanong ko lang kung san kaya ang reverse light switch and fuse ng Lancer EL 1996 ko? Di na kasi nailaw ang tail ko kapag aatras ako.
September 28th, 2015 08:43 AM #2312
nasa ilalim ng dashboard yan.
pagsilip mo sa ilalim ng steering wheel, may parang cabinet dun for fuses.
sundan mo na lang yung mapa.
- Sep 2015
- 4
September 29th, 2015 08:27 AM #2313Good day po mga sir, my lancer glxi 94 model itlog, ask ko lng po mga sir, ano po possible problem po ng auto ko ayaw pong mg start, ok naman po ung starter pero ung makina ayaw mgstart, nangangamoy nmn po ng gas kapag tinatapakan ko ung accrlerator, pg check ko s hightension wla pong kuryenteng ang spark plug ng change n po ako ng spark plug pero ganun p rin. please help nmn po or give me some idea po kung ano po pedeng i check. maraming salamat po
September 29th, 2015 08:47 AM #2314
- Sep 2015
- 4
September 29th, 2015 09:59 AM #2315n check ko n po ung hightension wire ok nmn po, my posible po bng pedeng remedyo po s distributor po salamat? o sadyang palitan na lng po, mga how much po distributor po, salamat po ng marami po
September 29th, 2015 11:09 AM #2316
sure ka na may enough spark yung mga HT wires? baka mahina na din.
distributor can fetch around 5k, brand new, OEM. pero check mo din muna, baka pwede pa i repair.
- Sep 2015
- 4
September 30th, 2015 10:40 AM #2317salamat po sir, kun surplus n distributor san po b mganda bumili ung cgurado at medyo mura lng po mga sir, salamat po ulit
September 30th, 2015 10:42 AM #2318
mahirap bumili ng surplus eh.... you will not know if the unit that you will be getting is good, or baka masira lang after 6 months.
sa akin kasi, if the unit can still be repaired, it would be a better option than getting a surplus one na hindi mo alam ang kondisyon.
san ba location mo?
san ba location mo?
- Mar 2008
- 54,263
September 30th, 2015 11:02 AM #2319i don't own an EL..
but in some cars, that reverse light switch is screwed onto the transmission housing, po.
it should be easy to see, as it's the only item there that has electrical wiring to it.
i don't own an EL..
- Sep 2015
- 4
October 5th, 2015 07:32 AM #2320mahirap bumili ng surplus eh.... you will not know if the unit that you will be getting is good, or baka masira lang after 6 months.
san ba location mo?
ah ok po sir, posible daw po ung magnetic coil ng distributor ung prob, san po kya pedeng makabili or ipa repair ung distributor po, tga makati po ako sir, salamat po ng marami
China's EV industry concerns. Here's what we know CNBC Television
China cars
