Results 1,091 to 1,100 of 2721
August 28th, 2013 05:32 PM #1091
- Jun 2013
- 159
August 30th, 2013 12:01 AM #1093
August 30th, 2013 08:28 AM #1094
August 30th, 2013 12:37 PM #1095
CONFIRMED!
May software problem nga yun head unit ng CX5. ito yun sinabi kong problema pag gamit ko ipod. im not sure sa mga naka 2.0 kung ganito din.
http://www.mazdas247.com/forum/showt...ation-problems
I'm about to file a complaint with the BBB in an attempt to get a response from Mazda about the problems with the stereo and navigation system. I thought I'd try and make a comprehensive list of known problems, if anyone has a moment and has things to add to the list, please let me know. The ones I know of so far:
1) iPod and USB storage of varying size take varying amount of time to 'mount' and can take as long as 25 minutes in the case of an iPod Classic. This has to be done every time power is restarted in the vehicle.
2) iPod and USB storage will not resume playback, but revert back to the first song after power is lost and restored.
3) While playing iPod, turning off the audio via the audio butting (as in, to mute the sound for instance). Upon powering up, the iPod screen is blank and requires the iPod to be unplugged and plugged back in, which also then exhibits both the issues above.
4) If while listening to iPod, FM or any other source is selected, switching back to iPod exhibits the same problem as in #3, a blank screen.
5) About 30% of the time I start the car, the iPod is simply not recognized, the screen greys out, and I'm required to unplug and replug the iPod to get it back.
sana tama itong pina order ko na rear fog sa kapatid ko. kung mali ito, sayang pera, ang mahal pa naman
August 30th, 2013 12:45 PM #1097
Interesting! May wiring diagram pa. Kelangan lang magbutas. Kung meron sana yung OEM mount good na 'to.
Aftermarket Backup Camera with Mazda OEM Screen
Tsikot Member Rank 3
- Aug 2004
- 2,452
August 30th, 2013 11:46 PM #1098oh good finding yan ser, kaya ako para iwas problema i just used USB/Thumb/Flash drive....
ser JohnM,
tingnan nyo previous post ni ser LRTan, the rear view camera was supplied by yours truly, if same camera is acceptable with you i can provide it.
- Feb 2010
- 46
- Jun 2013
- 159
September 2nd, 2013 05:42 PM #1100
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
